Nasty Wendy Isn't
Need Quick Help On Launching A Stocker!
Topic: Need Quick Help On Launching A Stocker! (Read 4172 times)
Scoobum
July 15 2016, 11:57:09 AM »
This is one of the locals who actually listens...and he's coming out with me tonite. This is a fresh engine from JB Racing that Dan installed. It's bone stock and will be running 94 Sunoco tonite at the stock boost level. Chip and injectors are new from Eric...AFPR...
boost gauge...SM. It was a peg leg and it now has a posi in it. Rear sway bar is stock...but it has air bags. I'm handcuffed...c
uz he informed me he's using 26 inch TA radials. I need help with a tire pressure to run and what pressure to run in the air bags. Stock turbo...stock convertor. The track will be empty...so I'll have plenty of practice runs with it. I don't think it has line lock. I'm unsure of the shocks he's running at all 4 corners. I'm gonna have him run it WFO till the 1/8th...and get out of it...and check the 02's. I'm gonna sit in the passenger seat and watch the SM for KR. If all's well, I'll let him run it through the 1/4. Fuel pump is new with a hotwire kit. Fuel supply should be fine. Open to suggestions to launch it.
Joe Buick
Bone Stock
Boost n00b
Re: Need Quick Help On Launching A Stocker!
July 15 2016, 12:47:51 PM »
On Radials!!! 18-20 psi
NOT more than 5 psi launches. Already they will be up in smoke.
You know the rest..
JB RACING
Shimy87
PSI: 2
July 15 2016, 12:50:48 PM »
any track prep? As you know I don't have good tires either. If no prep I'd guess you will be lucky to leave with much more than 1-2 lbs of boost. If there is some sticky put down mine would hook 3-4 lb launches before I started adding upgrades
Scoobum
July 15 2016, 01:19:24 PM »
Track prep is hit and miss on one of these practice evenings.
Scoobum
July 15 2016, 01:29:12 PM »
It also has an RJC 3 inch DP. I couldn't talk him out of it.
motorhead
PSI: 4
Reply #5 on:
July 15 2016, 02:24:08 PM »
I would bring it up against the converter to take the slack out of the drivetrain, and on the last yellow flat foot it. Chances are it will be laggy enough for the first 60' it won't roast the tires, but will have good momentum. As for tire pressure (assuming the rubber isn't hockey puck hard) I would do a short burnout in the parking lot to see if the tires are cupping or over inflated, adjust the pressure until the contact patch is black across the board. No need for John Force burnouts - other than for fun of course!
Scoobum
Reply #6 on:
July 15 2016, 02:51:10 PM »
Okay guys...heading out. We'll try everytbing suggested.
Scoobum
Reply #7 on:
July 15 2016, 11:01:27 PM »
Don did pretty well tonite...with a tire smoking 13.5x at 104x. High gear 02's were pig rich in the 870's.
Shimy87
PSI: 2
Reply #8 on:
July 15 2016, 11:31:12 PM »
larrym
PSI: 1
Reply #9 on:
July 16 2016, 12:57:14 AM »
Cool it will only get faster. How did it 60' on street tires?
Scoobum
Reply #10 on:
July 16 2016, 07:59:55 AM »
Larry, he got there late...and I was busy with the BS with my car. I watched all 3 of his runs. 13.8, 13.6 and 13.5. He races a 6 second snowmoblie in the 1/8th during the winter that runs 135 MPH on the big end. Don knows how to 'pedal' a car. He had it down cold by the third run.
TexasT
Legend in my own mind
PSI: 1
So, This black car is fast?
Reply #11 on:
July 16 2016, 09:15:46 AM »
It has decent mph for a stock unit. With traction it will do 13.0s. Maybe he had a good time and will spring for some tires to hook it up.
Reply #12 on:
July 16 2016, 09:35:52 AM »
Not bad for being that rich
