Author Topic: valve spring tool and trans shift parts  (Read 4114 times)
Offline tb3
« on: July 11 2016, 08:35:38 PM »
I have 2 things for sale.
first is a custom made valve spring remove/install tool.  It makes changing out the springs and seals super easy vs the common valve spring tool you may have or rent from the local parts store.   This is made specifically for the 3.8 engine and makes changing them a breeze (even #6 cyl)  It has a socket built into it for a 3/8's ratchet.  Comes with a spare rocker arm so you don't have to bully around yours when doing the job.
$45 shipped to the lower 48
second is the shifter parts that go from the column down to the trans.  All are in like new condition and have been media blasted and painted gloss black.  Includes everything you see in the pic.
$22 shipped to the lower 48.
Offline 1KWIKSIX
Re: valve spring tool and trans shift parts
« Reply #1 on: July 12 2016, 05:11:38 AM »
I'll take the valve spring removal tool. Shipping to Niagara Falls NY 14303
thanks
dave
Offline tb3
« Reply #2 on: July 12 2016, 06:04:56 PM »
$45 shipped.  I'll send you a pm
Offline tb3
« Reply #3 on: July 14 2016, 03:53:40 PM »
Everything is sold
