Author Topic: Power And Ground For WB  (Read 10783 times)
« on: July 07 2016, 05:25:26 PM »
Wheres the best place to grab 12 volts and to ground the WB.
Re: Power And Ground For WB
« Reply #1 on: July 07 2016, 10:28:51 PM »
Brad, there's two spots on the fuse block that you can use.  I think they're marked ignition. Single female terminal. I use the one bolt just above the e-brake for ground
« Reply #2 on: July 07 2016, 10:34:19 PM »
the best ground is either the engine block or the battery.  On one car, I drilled a hole thru the firewall and installed a bolt.  I hooked the ground up to this bolt under the dash and under the hood, I connected a ground strap to the engine from the same bolt.
The ign terminal should work ok for power.  On my AFX, I think I connected power to a switched ignition source under the hood and the ground to the battery ground where it connects to the inner fender.
« Reply #3 on: July 08 2016, 06:44:51 AM »
The problem I have had in the past with using the switched 12v source at the fuseblock is there are a finite number of connections to draw from.  I would add a 30/40A relay triggered by of the switched source, then you can run upto 3 10A circuits off this using direct power off the battery.  Ensure you run an inline fuse; and yes where possible ground to the battery or engine - don't count on underdash connections.
« Reply #4 on: July 10 2016, 10:32:43 PM »
Pulling the DP Tuesday in the AM and having the bung welded in. Gonna reinstall it in the eveining and wire it Wednesday morning. Hotter than hell up here...so I'm doing everything when it's cool.
« Reply #5 on: July 12 2016, 03:42:50 PM »
Removed the DP from the car this morning...had the bung welded in...and reinstalled the DP. Gonna wire it tonite when it cools out there. Thanks for everyones input.
« Reply #6 on: July 12 2016, 05:00:46 PM »
The PDF file for this WB says it draws a max of 3 amps...so I'm gonna install a 5amp in line fuse.
Question...wil l this WB read correctly at ALL throttle positions?
« Reply #7 on: July 12 2016, 06:17:48 PM »
It should....it is not heat and pressure sensitive like nb sensors
« Reply #8 on: July 12 2016, 06:24:17 PM »
Thanks Steve. I found a 3 amp fuse...so I used that. I hung it in the air for a few minutes as directed...and dialed it till it says CAL. I'm to kill the power...wait till it cools...and then install it. Fire it up...and it should read...correct?
« Reply #9 on: July 12 2016, 06:29:09 PM »
yep...pretty simple...takes a few seconds to warm up and start reading actual A/F.
« Reply #10 on: July 12 2016, 09:39:51 PM »
Seems to be working fine...thanks. :)
