Author Topic: HD Actuator-How To Test?  (Read 5186 times)
« on: June 23 2016, 04:50:48 PM »
How do I check this actuator to make sure it's working correctly?
Re: HD Actuator-How To Test?
« Reply #1 on: June 23 2016, 05:47:15 PM »
how much pressure does it require to fully open?
« Reply #2 on: June 23 2016, 05:52:30 PM »
What tool do I require to check for pressure?
« Reply #3 on: June 23 2016, 07:57:35 PM »
I found a hand vacuum/pressure pump at Canadian Tire for 70 bucks. Gonna check at Princess Auto tomorrow for a cheaper one. If not, I'll stop by a friends garage and have him check it. I'll get back with an answer ASAP.
« Reply #4 on: June 23 2016, 09:30:21 PM »
yeah, you need a low pressure source to see when it starts to ease open and at what point, it has made full travel
« Reply #5 on: June 23 2016, 09:39:49 PM »
One of those really cheap 12v tire pumps might work if you have a decent gauge you can plumb in
« Reply #6 on: June 23 2016, 11:10:08 PM »
You can buy a regulator w/gauge (like a that used for a HVLP paint gun) and hook it up to a compressor line.
https://www.google.ca/search?q=how+to+bench+test+a+wastegate&ie=utf-8&oe=utf-8&gws_rd=cr&ei=hKRsV--6KMnGetLTi7AF
« Reply #7 on: June 24 2016, 01:02:35 AM »
if you suck on it and it does not hold a vacuum, it's bad
« Reply #8 on: June 24 2016, 07:16:17 PM »
No one sells a pressure gun...and I tried several garages in town..to no avail. I emptied the air in the compressor and hooked the blow gun up with a screw in adaptor...and hooked a vacuum hose up to the actuator. I fired up the compressor and watched the pressure gauge. I doubt the pressure gauge is all  that accurate...but the arm began moving ABOUT 15 PSI...and hit full extension ABOUT 33 PSI. There were no air leaks when pressurized.
« Last Edit: June 24 2016, 07:21:51 PM by Scoobum »
« Reply #9 on: June 24 2016, 08:05:11 PM »
I didn't think of it earlier, I  guess a plumber would have one to pressure test his installation, at least the commercial guys used to do it.
« Reply #10 on: June 24 2016, 09:09:45 PM »
Too bad you don't have another one to test to compare.  Do you have a stock actuator laying around?  There should be about a five psi difference between stock and hd.
33 seems high to me but I don't know how far they should move to have the wastegate open.
« Reply #11 on: June 24 2016, 09:26:28 PM »
Steve, the guages on the compressor are incredibly small, so those numbers are a guesstimate. I haven't got a stocker to compare it too. I wanted to make sure it was working. Changing headgaskets isn't something I enjoy doing on a regular basis.
« Reply #12 on: June 24 2016, 10:55:59 PM »
The boost pressure actually helps the spring open doesn't it?
If you were to disconnect the line it would hold the puck closed longer until the exhaust pressure over came the spring?
33 psi overcame the spring would you not have to account for the exhaust gas pressure as well.
« Reply #13 on: June 25 2016, 12:29:06 AM »
The spring is what keeps the wastegate closed.  Boost pushes on the actuator causing it to over ride the spring pressure and open the gate.
It sounds like the actuator is working to me
« Reply #14 on: June 25 2016, 04:28:24 AM »
Man, if i had a dime for everytime I said.....
