Do I need a .005 under chain?
Topic: Do I need a .005 under chain? (Read 2067 times)
larrym
PSI: 1
June 21 2016, 09:55:52 PM »
My last motor it was mortal combat installing a new chain this seemed to go on too easy.
earlbrown
PSI: 6
Re: Do I need a .005 under chain?
June 21 2016, 10:51:02 PM »
A .005" set might more than make up that little bit of deflection.
Is the outside of that chain smooth enough to run a tentioner?
larrym
PSI: 1
June 21 2016, 11:17:43 PM »
No it's a link chain not smooth.
It has much less sloop the cam turns right away.
