Stumped
Pages:
2
3
4
Topic: Stumped (Read 15051 times)
Re: Stumped
Reply #15 on:
June 23 2016, 11:37:16 AM »
so what did you do about the valve?
motorhead
PSI: 4
Re: Stumped
Reply #16 on:
June 23 2016, 11:58:17 AM »
Were you cheated on all of the valves?
larrym
PSI: 1
Stumped
Reply #17 on:
June 23 2016, 12:24:36 PM »
Took the head to the machinist he touched up the seat and vacuum tested them set me up with 6 new seals on the exhaust valves as 4 were floating and not on the guides. Charged me an hour no parts he said my back pressure was pushing the seals off....
motorhead
PSI: 4
Re: Stumped
Reply #18 on:
June 23 2016, 12:56:41 PM »
I am no mathemagician but that would be some pretty serious (back)pressure to push all the way back up the port, and then up the guide in order to lift the seal, under load. Sounds like crappy fitting parts or setup from the get-go.
larrym
PSI: 1
Re: Stumped
Reply #19 on:
June 23 2016, 01:08:13 PM »
I agree Mike the old ones were the stock Felpro the new ones were steel caps no spring.
The liners in the guides were new and tight when I inspected them either the seals were not installed properly or they were too loose to start.
I pressure tested that cylinder after I torqued the heads sealed up so I'm happy. New chain and equal cylinder pressure I'm looking forward to getting it back in. I suspect my boost flutter will be less if at all once this is done.
Re: Stumped
Reply #20 on:
June 23 2016, 01:08:48 PM »
yeah...somethi
ng ain't right
larrym
PSI: 1
Re: Stumped
Reply #21 on:
June 23 2016, 02:03:00 PM »
so if it was yours car and you had a choice on cam timing would you run it 2 degrees advanced or 2 degrees retarded. My turbo spools pretty quick and lag is not really an issue.
Scoobum
Re: Stumped
Reply #22 on:
June 23 2016, 04:46:41 PM »
A while back two of the locals complained there cars were turds. I mentioned to them to check their cam timing. Since I don't know anything, about a year later they checked...and both cams were retarded. Go figure.
larrym
PSI: 1
Stumped
Reply #23 on:
June 23 2016, 04:59:41 PM »
Lol yes I know guys that don't check they just close their eyes and install the cam.
Most of the time it works out ok but you never know what you are leaving on the table.
Re: Stumped
Reply #24 on:
June 23 2016, 05:46:21 PM »
it's probably fine as it is, but, if I had my druthers, I would probably rather be +1 from the cam card on a street car
larrym
PSI: 1
Stumped
Reply #25 on:
June 23 2016, 06:08:40 PM »
My thoughts too thanks for the opinion
larrym
PSI: 1
Stumped
Reply #26 on:
June 26 2016, 03:44:33 AM »
Well now I'm beyond stumped.....
Motor is back in new head gaskets, timing chain, intake gasket, leaky exhaust valve sealed up. It's still lean at idle. Tested all the LS coils 1 is suspect I will swap it tomorrow. Than I guess it's time to try a fuel pump. I smoke tested it again.
larrym
PSI: 1
Stumped
Reply #27 on:
June 29 2016, 02:00:10 AM »
..... It's better but something is still a miss. I pulled the dog house and sealed everything again IAC TB power plate Dblock it still idles rough.
IAC is set at 10 TPS is .47 BLM is much better around 120 where it was before. it's late and I will play with it tomorrow. Got 2 extra plug wires I will swap them out 2 at a time and see if that's the problem my wee brain hurts.
Re: Stumped
Reply #28 on:
June 29 2016, 08:01:16 AM »
Tps is on the outside edge of the window. Lower it to make sure it stays in. Pull one injector connector at a time and see if there's a cylinder or two that does not make it worse
larrym
PSI: 1
Stumped
Reply #29 on:
July 01 2016, 11:47:47 AM »
Ok I might have found something? I went to start it when it was cold. Start stall, start stall hmm identical symptom to when I forget to plug in the MAF. I unplug the GENll translator fire it up and away it goes idling like a champ throws a code for low MAF but that's to be expected. Checked all the wiring to the GENll it appears fine. Gonna see if I can borrow a regular translator and a chip to try see if that changes anything.
I reset the IAC 20 and TPS .45 seemed to idle a little better.
Pages:
2
3
4
Stumped
