So had the car out testing the new seats got on it a bit when I was cruising back home noticed it was really lean and stumbling coming to a stop symptoms of a large vacuum leak drove home popped the hood and grabbed my stethoscope nothing obvious hmmm did a smoke test still nothing swapped the pcv no change. Compression test 5 at 150 # 5 at 135 that might account for the boost flutter. When you fire it up cold it fat idles good until it gets to temp then lean and rough. Tried another narrow band no change the part that really confused me is that there is very little change in the IAC it's right around 15 TPS is good too. My BLM has climbed from 120 at idle to 129.
