tire question
Pages:
2
3
Topic: tire question (Read 8359 times)
Re: tire question
Reply #15 on:
June 10 2016, 08:45:44 PM »
fixin' to slap Brad up side the head with my freaking purse....
For strip only, Brad is right
reality
Turbo Street Modified
Boost n00b
Re: tire question
Reply #16 on:
June 10 2016, 09:18:37 PM »
I agree with Steve on this one.
Besides Brad uses front wheel drive slicks so he has to put them on the front.
Shimy87
PSI: 2
Re: tire question
Reply #17 on:
June 10 2016, 09:54:30 PM »
That a 2 inch taller tire than what I have on now.....will that put my finish line rpm much lower?
Scoobum
Re: tire question
Reply #18 on:
June 10 2016, 10:00:33 PM »
Yes...your RPM's will be lower with a taller tire.
reality
Boost n00b
Re: tire question
Reply #19 on:
June 10 2016, 10:05:40 PM »
Each 1 in of tire height = approx 300 rpm at the stripe so 600 rpm lower.
Shimy87
PSI: 2
Re: tire question
Reply #20 on:
June 10 2016, 10:06:39 PM »
Wheres a good place to get a couple steel rims??
Re: tire question
Reply #21 on:
June 10 2016, 10:29:34 PM »
The question is where do you get an 8" wheel with 4" backspacing
Scoobum
Re: tire question
Reply #22 on:
June 10 2016, 10:36:10 PM »
C3 Vette rims? They're a dime a dozen up here.
good2win22
Re: tire question
Reply #23 on:
June 10 2016, 10:37:12 PM »
Summit has a pretty good filtering system on their website. Just select everything that you want in a wheel and it shows what they can get. A phone call to confirm wouldn't hurt. Here's a link with all the filters in place. I hope it works.
https://www.summitracing.com/search/department/wheels-tires/section/wheels/part-type/wheels/wheel-diameter/15-in/wheel-width-in/8-000-in/wheel-bolt-pattern/5-x-4-3-4-in/wheel-material/steel/backspacing-in/4-000-in?N=4294950865%2B4294920859%2B4294920860%2B4294920795%2B4294920825%2B4294947557%2B4294920856%2B4294920837&SortBy=Default&SortOrder=Ascending
Shimy87
PSI: 2
Re: tire question
Reply #24 on:
June 10 2016, 11:24:23 PM »
Thanks!! I like the cragger black and the price is right!! With a set of Mickeys and rims its about $500. Question is will the half second be worth it. Depends on what my buddys supercharged stang runs
Shimy87
PSI: 2
Re: tire question
Reply #25 on:
June 12 2016, 10:10:29 PM »
Ran 12.6 - 12.8 all day. Won 6 rounds of bracket to take first plact trophy. Ill post a couple slips tommorrow. Best 60ft was 1.88 with a finish of 12.638 at 105.17mph. Need some tires if I hope to get an 11 slip
my tune had SM recall 782 at 104 with 0 knock running 24 lbs off the line creeping to 25 by finishline. Couldnt leave with any boost. Tried one launch at 2 lbs and blew away tires. Great time today. Buddys mustang ran 11.5 all day.
TexasT
Legend in my own mind
PSI: 1
So, This black car is fast?
Re: tire question
Reply #26 on:
June 13 2016, 12:42:19 AM »
I'm guessing you let off toward the end. 105 isn't much mph for 12.60s. Should be in the 107-108 range. Though with a 1.88 60' it comes on strong to get to the 12.60s
good2win22
Re: tire question
Reply #27 on:
June 13 2016, 07:52:48 AM »
Looks to me that you have the big end tuned pretty close. No PL log?
Re: tire question
Reply #28 on:
June 13 2016, 08:31:39 AM »
How many mph did it pick up on the last 1/8?
TexasT
PSI: 1
Re: tire question
Reply #29 on:
June 13 2016, 08:41:35 AM »
With that 1.88 and ramping all the way up to 12.6 I would say he is at 78-79 in the eighth and it comes strong on the top end . Just a guess.
With that alcohol it needs more boost and might need a larger injector but more tuning and traction definitely.
Post us a time slip Shimy. And keep up the good work.
Pages:
2
3
tire question
