Author Topic: Removing Charcoal Canister-Questions  (Read 1899 times)
« on: May 25 2016, 06:33:48 PM »
Dan and I installed the new CAI unit which goes through the DS fender at the bottom. I have an ATR charcoal cansiter relocation kit. If I decided to do away with the charcoal canister...the n I have a couple of questions.
Will a code get kicked when I unplug it?
I assume I can cap off the vacuum line going back to the engine?
Can I leave the vent line open...to vent to the atmosphere...o r is there something else that should be done with the line?
Re: Removing Charcoal Canister-Questions
« Reply #1 on: May 25 2016, 09:27:05 PM »
No codes.    Do not fill the tank up to reduce the chance of fuel being pushed out the line. That would not be good
« Reply #2 on: May 25 2016, 10:44:40 PM »
With Eric's chips, you won't get a code.  I left the the one vacuum line to that can beneath the charcoal filter under the wheel well.  I left that one because I thought it might help with the vacuum brakes but who knows. Removed the other vacuum line completely. I used a zip tie to secure the fuel tank vent line between the header panel and the radiator.  No problems with a full tank so far.  You can remove all the EGR stuff as well.
« Reply #3 on: May 26 2016, 05:06:31 PM »
Thanks for the info gents.
