Zap *STILL* wears Depends
Jason and I were discussing how high gear fueling with Erics 5.7 chip affects overall fueling. Ambient air temp has been the same the last two weeks. Last week I pulled 5 percent high gear fuel...and note the low gear fueling came in at 807 with 15 percent low gear fuel pulled. Fast forward to this week. I added 5 percent fuel to high gear to compensate for adding 2 lbs of boost. The low gear fueling checked in this week at 823 with no low gear fueling changes.
Quote from: Scoobum on May 08 2016, 07:01:07 AMJason and I were discussing how high gear fueling with Erics 5.7 chip affects overall fueling. Ambient air temp has been the same the last two weeks. Last week I pulled 5 percent high gear fuel...and note the low gear fueling came in at 807 with 15 percent low gear fuel pulled. Fast forward to this week. I added 5 percent fuel to high gear to compensate for adding 2 lbs of boost. The low gear fueling checked in this week at 823 with no low gear fueling changes.Sounds like it works just like the instructions say it does
Quote from: Steve Wood on May 08 2016, 10:29:27 AMQuote from: Scoobum on May 08 2016, 07:01:07 AMJason and I were discussing how high gear fueling with Erics 5.7 chip affects overall fueling. Ambient air temp has been the same the last two weeks. Last week I pulled 5 percent high gear fuel...and note the low gear fueling came in at 807 with 15 percent low gear fuel pulled. Fast forward to this week. I added 5 percent fuel to high gear to compensate for adding 2 lbs of boost. The low gear fueling checked in this week at 823 with no low gear fueling changes.Sounds like it works just like the instructions say it does I'm sure it wouldn't surprise you how many folks that I've run into that don't understand this
Jim, the 7.4 equates to about 11.7x. SMP sticks to the rule book on race days...so I can't go much faster. I'll likely pull the last 5 percent out of low gear fuel and call it a day. A 1.6x launch is prolly about 7.2...which will cut it close for having no bar in the car for Sportsman Class.
