Author Topic: marshal's issues 87 GN  (Read 2512 times)
« on: May 05 2016, 07:02:10 PM »
I went ahead and started a thread. I'll put a link in the shout box.
Lean code 44
I would be looking for a leak in the intake past the maf. If you are running the stock cloth maf to turbo pipe I would bet a hole has formed. I have used electrical tape in the past but a metal pipe or new cloth pipe might be in order.
Next you might put a gauge on it to verify fuel pressure. It is spring, probably time for a new fuel filter anyway.
Re: marshal's issues 87 GN
« Reply #1 on: May 05 2016, 08:03:12 PM »
Also the 1st Tech thread is Steve's site vortexbuicks so you should spend some time reading as it has a wealth of easy to find & useful info.
« Last Edit: May 06 2016, 05:40:23 PM by Just a Six? »
« Reply #2 on: May 05 2016, 11:25:43 PM »
Do the MAF tap test, see if the idle wavers when you tap it
« Reply #3 on: May 06 2016, 08:21:00 AM »
Marshall,
Do you have a scanmaster?
« Reply #4 on: May 25 2016, 02:18:46 PM »
i guess marshal didn't make it back
