Author Topic: Barn motor and tranny swap  (Read 52835 times)
Re: Barn motor and tranny swap
« Reply #195 on: July 02 2016, 10:34:55 AM »
I'm not convinced that it's wiring, but some jumpers would answer that.
« Reply #196 on: July 02 2016, 10:38:47 AM »
Just the three we looked at fluctuated. Mine was 6.9-7.1 Jason had a bit higher and Jim said his was in the 16v range. Crazy different.
Jump it. I'm thinking it might show continuity but could be pinched, smashed or nicked and isn't carrying the voltage all the way.Jason said he would pull it out of the bundle but jumping it would probably be quicker and easier.
« Reply #197 on: July 02 2016, 10:47:15 AM »
They have varied a lot since they were new.  That's the reason, I am not convinced it's the wiring.  We have three components in play and a lot of wiring..but jumping should be easy and might prove it is  :)
« Reply #198 on: July 02 2016, 11:38:56 AM »
I'll throw a jumper in there but it will have to wait till tomorrow.  Headed to Pearland for an ATP check ride tomorrow morning
« Reply #199 on: July 02 2016, 04:55:38 PM »
Good luck on your ATP check!
« Reply #200 on: July 03 2016, 12:39:05 AM »
Jason=got the cam sensor back today :)
« Reply #201 on: July 03 2016, 10:40:15 PM »
Thanks Rich!  I passed the check ride.
Thanks Steve for the loan
« Reply #202 on: July 03 2016, 11:15:17 PM »
 :cheers:
« Reply #203 on: July 03 2016, 11:30:58 PM »
Well done Jason
« Reply #204 on: July 04 2016, 07:37:15 AM »
Thanks Larry!
« Last Edit: July 04 2016, 11:32:53 PM by good2win22 »
« Reply #205 on: July 04 2016, 11:18:14 AM »
Good...now get in the damn plane and fly to Picton Airfield...hom e of Armdrop. :)
« Reply #206 on: July 04 2016, 11:33:23 PM »
Someday Brad. Someday...
« Reply #207 on: July 05 2016, 05:45:52 PM »
Installed a jumper on the signal wire from the cam sensor to the ignition module. Went for a drive....
No change.  Got the 16 code again on the tach from the TR6.
Promptly removed the jumper wire and TR6. Installed the stock ignition module and coil. Went for a drive.  No codes.  Noticeably starts quicker than with TR6 unit and appears to idle smoother.
Decided to flush the coolant system and had this old heat shield laying around so I installed it. Charlie and Gary saw it on my white T, what do you guys think?
Offline Be4u
« Reply #208 on: July 05 2016, 06:22:19 PM »
I'm the kinda guy that likes the stock look and very much dislikes black heat shields
But yours is different. That's badass!
Save the bumper fillers!
Move to Canadia!
« Reply #209 on: July 05 2016, 07:12:31 PM »
Hate to say it...but I'm hooked on underhood bling. :icon_redface:
