Welcome to IHADAV8.com!
Made my first little road trip today after the swap. Went into Nitrous Outlet in Waco to meet a friend to wanted a set of headers that I had. 35 miles one way. Changed the oil and filter before leaving and reset the ECM before leaving on the trip. Some observations I had while ECM is in blm learning mode and viewing the wideband guage. Cruising at 65, blm at 131 so it's adding a bit of fuel but wideband is showing a bit on the rich side of stoich at 14 - 14.3. CC's we're counting at an acceptable speed. After staying for a while in Waco, I head home. ECM is now not stuck in learning mode as much and crushing at 65 on the way home I noticed that BLM has now come down to 127 and wideband is at 14.2 - 14.6. CC's still counting same as before. Only difference is that the ambient temp has dropped a few degrees. Thoughts? Can the SD chip allow fueling changes at cruise?BTW, car did great, not a single hiccup. (The proverbial knock on wood sign)
The cross flow muffler? That would be tight!
