Author Topic: for those that don't go on the other board....  (Read 7637 times)
Re: for those that don't go on the other board....
« Reply #15 on: April 01 2016, 09:59:46 AM »
I am assuming if they are a lightweight alloy, they expand quite a bit more than something like the old TRW forgings?  Rattle when cold?
« Reply #16 on: April 01 2016, 12:50:07 PM »
They're forged so they're going to make a little noise at cold startup.   They do require more room than a hyper but .003"ish cold isn't that bad.
That's one of the reasons I avoided using 2618 for the forging.
« Reply #17 on: April 02 2016, 10:16:08 AM »
that's not bad at all
« Reply #18 on: April 03 2016, 11:48:01 PM »
I expect to catch some flak for not using the ''better'' 2618 material....
...but we've been making over 100hp a hole for decades now with a stock high mileage cast slug.   Stepping up to a forging (and losing weight) is a leaps and bounds improvement no matter the material.   I chose less noise and lower price over unnessessary overkill.
The uber badass series bidness slugs 2.0 are in the works with the 2618, but that's going to me more of a racing slug for a ''street'' car in quotes. :)
« Last Edit: April 04 2016, 12:38:36 PM by earlbrown »
« Reply #19 on: April 04 2016, 11:01:19 AM »
I agree with you :)
