Author Topic: Can anyone identify this transmission?  (Read 10408 times)
Offline AZJoe
  • Newbie
« on: March 10 2016, 10:46:38 PM »
I have a TH200-4R that I want to rebuild to put in an El Camino. I'd like to know what I'm starting with, but so far I have been unable to decode the S/N. The scheme doesn't match anything I've found on the web. It's S/N is:
300-871CCF0793
Anyone know what car was a CCF? Or anything else from this S/N?
Thanks,
Joe
Re: Can anyone identify this transmission?
« Reply #1 on: March 11 2016, 08:47:04 AM »
Should be decent internals as it appears to be an 87 model. Not sure on the ccf. I'm guessing you don't know what it came out of. It should have the updated pump and such. I'd still look to put in new hard stator support and hard sunshell during the over haul. Check out my build thread and post up your questions. I'll try to help.
« Last Edit: March 11 2016, 08:57:25 AM by TexasT »
« Reply #2 on: November 08 2018, 08:07:20 AM »
In the last two years, we've all went with CVT transmissions.
Every single one of us.
« Reply #3 on: November 08 2018, 08:25:49 AM »
I'm gonna put an 18 speed from a big Mack truck in mine.
Offline reality
« Reply #4 on: November 08 2018, 09:25:51 AM »
I'M going 6x4 with a 2 speed rear end.
Offline Grumpy
« Reply #5 on: November 08 2018, 10:18:44 AM »
What new things have happened to tell me how much development has been made today?
LOTs of $$$$$.  :rock:
« Reply #6 on: November 08 2018, 07:48:54 PM »
This makes for an interesting read with the spam now removed.  :icon_eyes:
