Author Topic: Ported throttle body/plenum/vac block and coolant lines  (Read 3575 times)
Offline tb3
« on: February 27 2016, 06:46:38 PM »
I have a completely rebuilt and port matched by Throttlebodys. com 86/87 throttle body and intake plenum, with RJC Power Plate.  And also the matching aftermarket vac block.  Aprox 500 miles on it.  No issues.  Gaskets included.  The throttle body has has the coolant nipples removed.  I will also throw in a set of coolant lines that do not have the tb coolant line nipples on them.  Clean up the look of the engine compartment and take away 2 more chances of coolant leaks.
The RJC power plate has a bolt and nut through the EGR hole as I was not using the EGR.  If you are using the EGR, simply remove the bolt and nut and you are good to go.
$350 shipped to the lower 48 for all of it.
I am also listing this on another board, so I have to treat it as first come, first serve.
Offline tb3
Re: Ported throttle body/plenum/vac block and coolant lines
« Reply #1 on: February 28 2016, 10:28:15 AM »
the throttle body is ported to a 62mm.
 Also includes brand new gaskets for the IAC Valve
 I can also media blast the vacuum block and plenum to bare aluminum if preferred.
Offline tb3
« Reply #2 on: February 28 2016, 01:36:26 PM »
sold
