Author Topic: tuners  (Read 15069 times)
tuners
« Reply #30 on: March 06 2016, 02:10:47 PM »
You wanted to see this correct ?
Re: tuners
« Reply #31 on: March 06 2016, 07:33:26 PM »
Yes. To write to a screen is more accurate to graph than to update numerical. A display only has to use a minimal amount of pixels to display "one dot" on the progression of a graph.
tuners
« Reply #32 on: March 06 2016, 07:52:18 PM »
Thanks for the help I'm getting closer I think. Still have to add fuel from 3000 to 4500  which I have but no point trying to log anything roads are wet.
The graph was hard for me to wrap my head around at first but it's clearer now.
tuners
« Reply #33 on: March 17 2016, 08:55:45 PM »
Hello I think I have it pretty much licked but your opinion is valued 😄
Here's screen shot of my latest log leanest it went was 12.47 just before it started to spray which is set at 5 psi 1 green light on the knock gauge but that could have been anything.
Re: tuners
« Reply #34 on: March 17 2016, 09:47:36 PM »
What is red line Larry?  I see numbers that confuse me a little. Also, what is low blue line. Red has number of 124.85  then goes off the chart.  MAF?   And the low blue line has a number of 4.37. TPS maybe?    Where you paused it at
Re: tuners
« Reply #35 on: March 17 2016, 09:58:58 PM »
red is load its off the graph dark blue on the bottom is boost  dark blue on top is TPS thanks for looking took me a while to wrap my head around the display
Re: tuners
« Reply #36 on: March 17 2016, 10:59:41 PM »
Looks to me that you really smoothed out the AFR from the earlier posted pic of the graph. The small little lean "hump" is almost gone on the most recent graph that you posted
tuners
« Reply #37 on: March 17 2016, 11:26:41 PM »
Yes things are improving I think.
Is 12.5 to lean for 5 psi as it transitions to ALKY it pulls good 😀
Re: tuners
« Reply #38 on: March 18 2016, 08:09:17 AM »
It is still rich.  12.5:1 at 3550 rpm may not be/look so bad if you can get the AFR closer to 11 to 11.5:1.  I know I almost shit my pants when I got our Procharged TBSS tuned from 10:1 to 11.5:1 AFR - it pulled that much harder to redline.  Obviously depending how much meth you are spraying will have implications on your target AFR, as it is typically run that much richer vs. gasoline.
tuners
« Reply #39 on: March 18 2016, 11:29:22 AM »
Yeah the boost is down so it's fat I was more concerned about the transition to meth before I started playing with the Max AFR 11.5 scares me for full boost! I try to keep it under 11.0, 10.6 to 10.7 at 27 psi is my comfort zone and no knock.
tuners
« Reply #40 on: March 25 2016, 06:40:48 PM »
Latest log think it's almost time to add some timing and turn up the boost.
I reconfigured the display the orange line is fuel adjustments.
Re: tuners
« Reply #41 on: March 25 2016, 11:10:41 PM »
Looks pretty steady now Larry. Was it the alky turn on point that you adjusted?
tuners
« Reply #42 on: March 25 2016, 11:56:53 PM »
No I adjusted my fueling on genll you can see the fueling added in the orange line I added fuel at the rpm and load point I was seeing the lean spike at worked pretty well now I can add some timing had set at 19 degrees I will try and find out what it likes just glad to see the knock gone when punch it.
tuners
« Reply #43 on: April 03 2016, 03:42:43 PM »
Ok pretty happy with the fueling right now.
So I have the boost set at 22-23 psi alky is coming on at 7 psi max duty at 20 psi. 22/20 degrees of timing with no knock it's still a little fat up top I was thinking I would up the max duty cycle on the Alky to 26 psi that's where I run it at the track. That should get my AFR close to 10.7
Probably going to add a bit more timing too.
Re: tuners
« Reply #44 on: April 03 2016, 04:14:53 PM »
I'd find out what Eric uses for his high gear timing default for alky...and use that...and leave it alone. Put the boost to it. :rock:
