Author Topic: Knock, Knock, Whos There? Help!  (Read 113143 times)
Offline deathraider6996
  • PSI: -1
Re: Knock, Knock, Whos There? Help!
« Reply #75 on: March 22 2016, 06:55:36 PM »
Zimmerman's machineshop in Phoenix comes to mind as among the best.
I'll check them out. I was talking to Bob Ostercamp about doing the work.
Sent from my SM-N910T using Tapatalk
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Duttneck Intercooler
3200 Vigilante Converter
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
  • PSI: -1
« Reply #76 on: March 22 2016, 06:56:44 PM »
St
PSI: 26
[Boost] [Vacuum]
View Profile
 http://www.vortexbuicks-etc.com/
 Personal Message (Offline)
« Reply #69 on: Today at 11:15:13 AM »
Quote
 Steve said.
if the bearings are bad, there is a very good chance that the crank will need to be resized and the rods also reworked....if you want to insure long long life...
the journals must be inspected and mic'ed to know how serious the problem is.
The OP said he has a GUY to look at the engine- not very inspiring unless he is experienced in Buick motors.
take it to a buick specialist like Nick and drop it off and wait. IMO.
I know to go to Buick specialists.
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
« Reply #77 on: March 22 2016, 09:19:47 PM »
google tells me Bob Ostercamp is a midas muffler dealer?
  • PSI: -1
« Reply #78 on: March 22 2016, 09:48:25 PM »
I'm going to use Zimmerman.
« Last Edit: March 24 2016, 02:23:21 AM by deathraider6996 »
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
  • PSI: -1
« Reply #79 on: March 22 2016, 09:48:40 PM »
He works on the ones in the hangar and the ones at his house are his. He knows Richard Clark closely. I think I'm just going to use Richard Clark's builder.
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
  • PSI: -1
« Reply #80 on: March 24 2016, 02:20:59 AM »
Is there anything wrong with vatozone water pump new replacements?
I've heard the ac delete belts are 1 inch shorter in length.  Any input on this?
I have disconnected the slew of wires running next to the driver side valve cover, fuel injector harness, and ignition wiring. The ground on the heads and a couple on the starter are the rest to be able to pull the motor, correct?
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
« Reply #81 on: March 24 2016, 07:17:34 PM »
fuel lines at the frame, I just unbolt the accessory bracket leave the power steering pump and bungy it out of the way pay attention to the reservoir it is delicate and easy to break.
« Reply #82 on: March 24 2016, 11:30:25 PM »
the delco pump from highway stars seems to work $37~
  • PSI: -1
« Reply #83 on: March 25 2016, 03:02:07 AM »
Thank you! motor is ready to pull!
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
  • PSI: -1
« Reply #84 on: March 25 2016, 06:57:03 PM »
Yup... Still yet to pull the heads
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
  • PSI: -1
« Reply #85 on: March 25 2016, 07:13:32 PM »
Passenger side head. Head gasket intact.
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
« Reply #86 on: March 26 2016, 12:04:43 AM »
lotsa debris on that pick up!
that engine is pretty nasty looking
« Reply #87 on: March 26 2016, 06:34:26 AM »
Definately time for a rebuild
« Reply #88 on: March 26 2016, 07:04:45 AM »
I'm betting the sludge in the bottom is bearing material. Can you feel any ring ridge with your fingernail?
« Reply #89 on: March 26 2016, 07:13:33 AM »
Fire ring appears split and distorted between cylinders in one of the pics. Pistons are wet and oily. Likely running rich...and what heat range were the plugs?
