Author Topic: Knock, Knock, Whos There? Help!  (Read 113076 times)
Offline deathraider6996
  • PSI: -1
Re: Knock, Knock, Whos There? Help!
« Reply #45 on: March 05 2016, 04:40:39 AM »
what did the plugs look like when they came out any really clean ones?
Nope all the same.
Sent from my SM-N910T using Tapatalk
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Duttneck Intercooler
3200 Vigilante Converter
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
  • PSI: -1
« Reply #46 on: March 05 2016, 04:42:16 AM »
Call NASA and tell 'em to crank up the Hubble Space Telescope to search for your headgaskets orbiting the planet. That knocking sound you're hearing...that's consistent with RPM...mite be a rod bearing that's been pounded into tinfoil from KR.
I really wish I never saw your comment... Guess I'll pull the heads...
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
  • PSI: -1
« Reply #47 on: March 05 2016, 04:42:59 AM »
Wouldn't there be metal in the oil?
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
« Reply #48 on: March 05 2016, 08:36:10 AM »
I had that exact thing happen to me. One half of only 1 rod bearing was flattened out & noise went with RPM. Try unplugging the injectors 1 at a time. That's how Norbs & I found the issue. Machine shop confirmed what we thought it was. Weird it was only one but that's all it takes!
"Wouldn't there be metal in the oil??
Not really, it was pancaked but it wasn't torn apart at all. Looking at it I saw nothing until Martin measured it.
Online 1 RARE T
« Reply #49 on: March 05 2016, 10:00:32 AM »
Sounds more like the right head gasket is blowing compression out the side.
Pull the heads.  :O
Rod bearing flat isn't what he's hearing I don't think.  :icon_neutral:
« Reply #50 on: March 05 2016, 10:22:17 AM »
That's my guess, too.
Mike is usually right!
« Reply #51 on: March 05 2016, 10:44:05 AM »
Either way seems that the heads are coming off. Oh well shit happens!
« Reply #52 on: March 05 2016, 11:38:30 AM »
If you can get it to run pull plug wires 1  at a time it should get quieter when you kill the spark to rod making the noise.
« Reply #53 on: March 05 2016, 11:44:27 AM »
Pulling injector connectors is less painful🙉
« Reply #54 on: March 05 2016, 11:52:41 AM »
And it does not hurt the module, either
« Reply #55 on: March 05 2016, 12:56:13 PM »
Never thought of that!
  • PSI: -1
« Reply #56 on: March 09 2016, 02:02:50 AM »
In the slow/learning process of removing the heads I found these metal chunks in the little pools of oil under the rocker shaft.
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
« Reply #57 on: March 09 2016, 09:37:37 AM »
I'd get after the previous owner for "selling' you that car with a faulty headgasket.
Noticed that he doesn't seem post here anymore....
« Reply #58 on: March 09 2016, 10:55:03 AM »
That's just a lack of maintenance, could happen to anybody, right?
Brings to mind some Latin, " caveat emptor".
« Reply #59 on: March 09 2016, 01:52:16 PM »
Its possible that is graphite from the head gasket, make sure you drop the pan and inspect the pickup and clean out any debris. How was your oil pressure?
