Author Topic: Knock, Knock, Whos There? Help!  (Read 112982 times)
Re: Knock, Knock, Whos There? Help!
« Reply #30 on: February 23 2016, 10:59:18 PM »
Take a cigarette pack and cut a piece 3/8" wide and 3" long then loosen the sensors and slide the card board in long ways threw the slot, then push the sensor up tight to the card board and tighten the sensor back down then pull the card board out and you will have the 25 tho you need. It works every time.
I heard rumour of a GN up in Canada that's gone 6.7 with stock junk and a few bolt ons that uses that method.
Offline 278CIKILLER
« Reply #31 on: February 24 2016, 02:40:54 PM »
Like Brand and I say keep it simple and you can't go wrong.
« Reply #32 on: February 24 2016, 06:49:28 PM »
I need to learn to read....smh
Did you check the clearances to see if you had 0.025-0.030 inches between that side of the blade and the slot in the damper?  Damn sure iooks like it is rubbing!  That may be the source of the ticking there.
When you watch it at idle...be watching it when the engine is cranked and see if the crank moves in or out to that it then touches.  Thinking about a worn thrust bearing
I checked it with a home Depot gift card and it's a little thinner in size but I figured its a good start. Well the cards can't even slide through, there isn't enough room. I tested it with all three fins.
Sent from my SM-N910T using Tapatalk
I set mine with a piece of a Coke can... which is slightly healthier than smoking.
Offline 278CIKILLER
« Reply #33 on: February 24 2016, 07:49:20 PM »
You keep wasting your money on coke and your car. Your waste not mine.
« Reply #34 on: February 24 2016, 08:03:07 PM »
I use a  plastic coke bottle
« Reply #35 on: February 24 2016, 09:50:01 PM »
gives you a nice pre-curved feeler gauge!
« Reply #36 on: February 25 2016, 01:15:24 AM »
You gotta love a Curved Feeler Gauge!
« Reply #37 on: February 25 2016, 08:36:47 AM »
A banana works for bigger gaps!
Offline deathraider6996
  • PSI: -1
« Reply #38 on: March 03 2016, 10:19:41 PM »
Well guys, I took there adjusted the crank sensor with the aforementioned cigarette box method. I then went to start it up and it wont idle without shutting off. I can rev it a little bit to keep it from shutting down but of course the knocking sound it back. Still constant with RPM.
It is also smoking like crazy from the tail pipes. White smoke. lots of cloudy white smoke.
new plugs, oil, filter, radiator, radiator fluid,
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Duttneck Intercooler
3200 Vigilante Converter
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
« Reply #39 on: March 04 2016, 09:52:55 AM »
back to the blown head gasket, I think
« Reply #40 on: March 04 2016, 02:41:00 PM »
Have we put a compression gauge on it yet?
  • PSI: -1
« Reply #41 on: March 04 2016, 03:33:37 PM »
Yes sir, all +/- 5 of 120
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
  • PSI: -1
« Reply #42 on: March 04 2016, 03:35:53 PM »
Thats what I'm thinking.
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
« Reply #43 on: March 04 2016, 04:00:49 PM »
what did the plugs look like when they came out any really clean ones?
« Reply #44 on: March 04 2016, 04:33:21 PM »
Call NASA and tell 'em to crank up the Hubble Space Telescope to search for your headgaskets orbiting the planet. That knocking sound you're hearing...that's consistent with RPM...mite be a rod bearing that's been pounded into tinfoil from KR.
