Author Topic: Knock, Knock, Whos There? Help!  (Read 113077 times)
Offline reality
Re: Knock, Knock, Whos There? Help!
« Reply #180 on: April 10 2016, 03:24:25 PM »
 I've broken/seen others break too many times even with stock stuff to suit me. Including 455's. You guys have more nerve than me!
 As far as weight roller cams are designed with roller rockers in mind -stockers not so much.
The stability and adjustment are worth the rollers to me?
Maybe with HD shafts.
Where do you get the buttons now?
« Reply #181 on: April 10 2016, 03:37:00 PM »
TA Performance
« Reply #182 on: April 10 2016, 05:48:04 PM »
I run solid rocker shafts with this flat tappet cam. Broke a couple of rockers over the years. I popped a coil and dropped 2 cylinders a year or so ago...was like I threw a boat anchor out it slowed so fast.
Offline deathraider6996
  • PSI: -1
« Reply #183 on: April 10 2016, 06:00:19 PM »
http://www.summitracing.com/int/parts/cca-k69-300-8/overview/
Only thing is that I don't need a timing chain. There was little to no play and doesn't have many miles on it.
Sent from my SM-N910T using Tapatalk
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Duttneck Intercooler
3200 Vigilante Converter
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
« Reply #184 on: April 10 2016, 06:07:44 PM »
« Reply #185 on: April 10 2016, 06:09:10 PM »
Stock appearing or roller?
Offline reality
« Reply #186 on: April 10 2016, 08:47:31 PM »
[/quote]
[/quote]
You don't know that yet. What does the machine shop say.
  • PSI: -1
« Reply #187 on: April 17 2016, 04:50:13 PM »
[/quote]
[/quote]
That's true. I'm getting everything ordered then I'll contact them.
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
  • PSI: -1
« Reply #188 on: April 17 2016, 04:50:56 PM »
Roller
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
  • PSI: -1
« Reply #189 on: April 17 2016, 04:54:08 PM »
I may not have needed these but for 250 shipped, I couldn't say no. Got them from some auto salvage yard. Arp hardware, not sure of the rods except they have the two dots, je pistons 20 over.
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
« Reply #190 on: April 17 2016, 07:42:41 PM »
Have the machine shop check the big ends for size...and have 'em check the rods for straight.
  • PSI: -1
« Reply #191 on: April 17 2016, 08:57:27 PM »
I will definitely have them do that. Thank you for that info. :rock:
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
  • PSI: -1
« Reply #192 on: April 24 2016, 02:53:59 PM »
Little update:
Dropped the motor off at Zimmerman racing engines in Phoenix. Says the crank will need to be grinded(?) in three weeks it'll be ready with a 1700 price tag. Forgot my front cover, they will open up the oil passages, blueprint, and rebuild the oil pump. He didn't mention the heads witch I forgot to bring up. Pretty sure I should bring them up and just have him install them.
Just noticed that the heads didn't have arp bolts, let alone studs, which I was told it did from someone. They were the stock tty sps bolts. So either the headgasket had been replaced and the old bolts were reused or they had never been off.
I'm a indecisive fucker. I eventually went with a 212/212 comp flat tappet cam. Lifters, chain, gears, pushrods, valve Springs, valve seals, retainer caps, and retainers.
I need to find a place to buy all the vacuum hoses so I can replace all of them.
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
« Reply #193 on: April 25 2016, 09:02:30 AM »
Grinding the crank just means that they need to be cleaned up to get a good surface for the bearings to ride on.  You can bet on at least a .010 over sized bearing, possibly a bit bigger depending on how much material has to be removed.
« Reply #194 on: April 25 2016, 09:26:28 AM »
It seems we often get sold things that are imaginary when we look.  All we can do is remember and not make the same mistake twice :)  I have a few of those t shirts.
Should be really nice when you get thru!
