Author Topic: Knock, Knock, Whos There? Help!  (Read 113143 times)
Offline deathraider6996
  • PSI: -1
Re: Knock, Knock, Whos There? Help!
« Reply #150 on: April 05 2016, 09:53:31 AM »
should be fine.   Question that I have is where did the white smoke come from?
That's the question of the day. I don't have the slightest idea
Sent from my SM-N910T using Tapatalk
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Duttneck Intercooler
3200 Vigilante Converter
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
« Reply #151 on: April 05 2016, 10:35:27 AM »
Any of the piston tops really clean?
« Reply #152 on: April 05 2016, 10:45:52 AM »
Make sure they check the heads and block for cracks.....
  • PSI: -1
« Reply #153 on: April 06 2016, 02:43:03 AM »
None look any different than the others.
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
  • PSI: -1
« Reply #154 on: April 06 2016, 02:43:43 AM »
Bleh... I was unfortunately thinking the same thing.
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
  • PSI: -1
« Reply #155 on: April 06 2016, 02:27:06 PM »
Will this new oil pickup work fine? There is a bar and the mesh is bigger.
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
Offline 278CIKILLER
« Reply #156 on: April 06 2016, 03:14:37 PM »
Wrong one, go to RockAuto.com they have them there, you will see the difference in the pics.
  • PSI: -1
« Reply #157 on: April 07 2016, 12:29:08 PM »
They both look the same as the one I have here.
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
  • PSI: -1
« Reply #159 on: April 08 2016, 11:28:47 AM »
Why does one not match the other.?
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
« Reply #160 on: April 08 2016, 12:20:46 PM »
One has a thrust surface.
Offline 278CIKILLER
« Reply #161 on: April 08 2016, 04:41:34 PM »
The oil pick up you need from rock auto ,part number s201s2.
  • PSI: -1
« Reply #162 on: April 08 2016, 05:07:27 PM »
Thank you.
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
« Reply #163 on: April 08 2016, 05:19:44 PM »
s201s2 same as the other one from Rock Auto.
Grab the TA one that Steve linked up
« Last Edit: April 08 2016, 05:24:42 PM by Just a Six? »
Offline 278CIKILLER
« Reply #164 on: April 08 2016, 06:10:16 PM »
I just purchase one a week ago from RockAuto and that's not the one they sent me. It has a full screen not the plate in it.
