Author Topic: Knock, Knock, Whos There? Help!  (Read 112983 times)
Offline deathraider6996
  • PSI: -1
« Reply #15 on: February 22 2016, 07:39:56 PM »
It looks like it's been making contact due to it being shiny(for lack of words)
The bracket is tight. The plug is tight.
« Last Edit: February 22 2016, 07:46:22 PM by deathraider6996 »
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Duttneck Intercooler
3200 Vigilante Converter
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
  • PSI: -1
« Reply #16 on: February 22 2016, 07:41:54 PM »
I will be able to crank and idle it once I'm able to delete the oil adapter(have to buy a bigger socket, which I don't know the size?)
Sent from my SM-N910T using Tapatalk
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
Re: Knock, Knock, Whos There? Help!
« Reply #17 on: February 22 2016, 07:45:51 PM »
guess you are gonna have to read that link I gave you!
Offline 278CIKILLER
« Reply #18 on: February 22 2016, 09:07:33 PM »
1 1/8" socket.
  • PSI: -1
« Reply #19 on: February 22 2016, 09:58:37 PM »
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
  • PSI: -1
« Reply #20 on: February 23 2016, 03:44:52 AM »
Alright so i had my friend manually turn the motor over while i looked at the blades. All three looked the same and were not touching. i am confused by this. the blades are too clean and fresh looking to not be rubbing.
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
« Reply #21 on: February 23 2016, 09:41:44 AM »
I need to learn to read....smh
Did you check the clearances to see if you had 0.025-0.030 inches between that side of the blade and the slot in the damper?  Damn sure iooks like it is rubbing!  That may be the source of the ticking there.
When you watch it at idle...be watching it when the engine is cranked and see if the crank moves in or out to that it then touches.  Thinking about a worn thrust bearing
« Last Edit: February 23 2016, 09:49:29 AM by Steve Wood »
« Reply #22 on: February 23 2016, 04:44:07 PM »
Grab a cheapass magnetic dial indicator and check your crank end play.
  • PSI: -1
« Reply #23 on: February 23 2016, 06:12:03 PM »
I checked it with a home Depot gift card and it's a little thinner in size but I figured its a good start. Well the cards can't even slide through, there isn't enough room. I tested it with all three fins.
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
  • PSI: -1
« Reply #24 on: February 23 2016, 06:13:10 PM »
Can I find those locally, or are the mostly online?
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
« Reply #25 on: February 23 2016, 06:22:07 PM »
that should be about the right clearance.  Set it with that....bet that fixes it
Offline 278CIKILLER
« Reply #26 on: February 23 2016, 06:51:00 PM »
Take a cigarette pack and cut a piece 3/8" wide and 3" long then loosen the sensors and slide the card board in long ways threw the slot, then push the sensor up tight to the card board and tighten the sensor back down then pull the card board out and you will have the 25 tho you need. It works every time.
« Reply #27 on: February 23 2016, 08:55:37 PM »
LIKE!
« Reply #28 on: February 23 2016, 10:56:36 PM »
Princess Auto has 'em...mite be a Canadian thing tho.
« Reply #29 on: February 23 2016, 10:59:06 PM »
translation: harbour freight=  magnetic base + dial indicator
