some one rode that thing hard and put it up wet before you got it. Amazing how durable these things can be.
Quote from: Steve Wood on March 29 2016, 08:39:53 PMsome one rode that thing hard and put it up wet before you got it. Amazing how durable these things can be.Theres no doubting that. 150k miles and my love for boosted driving didnt help the case. oh well, ill take this time to learn as much as i can. just got to make sure that i dont overwhelm myself and take my time.
Just going by his signature he is way beyond "stock" OPJust would like to ask -How did the suspension mods work for you? Got any 60ft times or 1/4 mile times etc.
Quote from: deathraider6996 on March 30 2016, 07:16:27 AMQuote from: Steve Wood on March 29 2016, 08:39:53 PMsome one rode that thing hard and put it up wet before you got it. Amazing how durable these things can be.Theres no doubting that. 150k miles and my love for boosted driving didnt help the case. oh well, ill take this time to learn as much as i can. just got to make sure that i dont overwhelm myself and take my time. If I had any advise to give it would be this. Set some goals with the engine build for your desired outcome and stick with it. Then research, research research! Get a notebook and write the stuff down. You will forget. You can go balls deep into your wallet if not. Not all of the cool guy parts are needed. The weak link in your build, mechanically speaking, will be your stock transmission depending on the power level that you initially set your goals for. Sometimes, stock power is enough to break your tranny. Watch the big board, facebook and this site for stuff that people are selling. You can save a fair amount of money buying second hand. Buyer beware! There are reputable sellers and then there are some SOB's. Shop all the vendors supporting our cars. Some sell items lower than others. Some have better customer service than others. When you finally get it all together, start with the basics and always go back and check them. Fuel pressure, O2 mv at idle, IAC counts at idle, TPS voltage, MAF at idle, vacuum leaks, exhaust leaks, voltage at the ecm and fuel pump. Did I mention vacuum and exhaust leaks? Last and probably the most important, everyone has an opinion on what's best. Choose wisely who's information you decide to trust.Good luck my friend! It's going to be a fun ride!
Quote from: Steve Wood on March 29 2016, 08:39:53 PMsome one rode that thing hard and put it up wet before you got it. One previous owner ? (wink)
Area under the curve! That's the fancy term.On the track a hyd. cam might be just as quick as a roller but won't have the same feel as a roller. A roller has steeper ramps than a roller. IMO for a street car go roller and don't look back and it's not really $900 if you are buying a cam and lifters anyway. Consider where your motor spends most of it's time on the street =mid range.Go roller and don't look back. imo.
Firing it up and bringing it to 2500 rpm and holding it there watching the headers glow and praying it doesn't over heat while you are breaking in a flat tappet spooks me.
