did you pull the hose off the turbo inlet and check to see if the blades are spinning freely and not touching the housing?Is it still ticking? Pulled all the plugs to see if they look normal?O2's etc look normal
run your hand along the seam with the block below the plugs to see if you feel any hot air coming out from a blown hg?
A few years ago I had a loud tick that went up with RPM & was loudest from under/around the Turbo cover. My Crank Sensor was somehow moved & rubbing but it sure sounded like it was the top end & not underneath until I finally stuck my head under the car.
