Author Topic: If someone doesn't say something I'm going to go crazy!  (Read 8540 times)
Re: If someone doesn't say something I'm going to go crazy!
« Reply #30 on: February 18 2016, 11:55:40 PM »
The car runs if you put some gas in the throttlebody.  Obviously, it has spark.  It also has proper fuel pressure but there is no gas coming thru the injectors even tho' it has injector pulse which should be spraying every time the injectors pulse.  Eventually, it should at least pop, backfire, or something.
Car has sat for years.  The injectors are not working because they are gummed up.  It needs cleaned injectors or new injectors.
I have seen this a number of times and I have seen injectors that were cleaned that would not work after setting on the shelf for six months.  Usually, in that case, they will start working if you "rattle" each one with a an extension and a small hammer.
If the fuel pressure was low, I would suspect that was the problem..in this case, they have 40 psi.  In this case, everything works but the injectors.
Cranked up with a new set of injectors....
« Reply #31 on: February 19 2016, 12:24:08 AM »
Nice as painful as it was I'm glad to hear it's running!
« Last Edit: February 19 2016, 11:13:49 AM by larrym »
Offline Be4u
« Reply #32 on: February 19 2016, 03:37:04 AM »
lol
Save the bumper fillers!
Move to Canadia!
