Author Topic: Mease stock location intercooler  (Read 3329 times)
Offline poppy1440
« on: February 14 2016, 03:32:23 AM »
Hello,  the previous owner of my car apparently cut the side of the intercooler shourd in order for the front sway bar to fit.
I have a HR Bar at and have no intentions on re-installing the front bar.
My question is besides for cosmetic reasons, will I benefit anything from fabricating something to close in the sides or finding something to close in the sides.
Thanks
86 gn. Champion irons, roller cam,stock location stretch intercooler, 3" exhaust," DP, scan master, red Armstrong  pump hot wired,  60 lbs injectors, Razors' alky kit, 6265, 6.0 chip, powerlogger, plx-afr, mt 275/50r15 et street
« Reply #1 on: February 14 2016, 09:23:20 AM »
Doubt it
Re: Mease stock location intercooler
« Reply #2 on: February 14 2016, 10:22:37 AM »
Notching the shroud is normal with that intercooler as I recall.  So do what you feel is best for you.
« Reply #3 on: February 14 2016, 11:02:20 AM »
Interesting . At what speed would we say the the air pushed by the MPH dominates the pull from that little fan?
« Reply #4 on: February 14 2016, 11:29:31 AM »
I have a Precision & it comes cut for the front bar with some adjustable plates that screw on. I messed them up & made a couple new ones. Used it closed up for years & now open with a hollow front bar & no difference I can tell? I haven't used the stock fan since I got it either.
« Reply #5 on: February 14 2016, 12:07:45 PM »
Logging your IATs on the outlet side before/after would be all you need to do.
« Reply #6 on: February 14 2016, 01:54:51 PM »
It would be difficult to prove any advantages connected to the factory fan.  KB once had an IC fan shroud that was intended to enable it to draw air thru the IC rather than the adjacent air.
Offline poppy1440
« Reply #7 on: February 14 2016, 05:40:48 PM »
Thanks
Offline tb3
« Reply #8 on: February 14 2016, 10:37:32 PM »
I had one of them ken belle intercooler shrouds.  Was a nice tight fit around the fan.
I was told it was actually a restriction for the air going through it once you get over about 40 mph, but not sure if thats true or not
