Author Topic: Caspers Gen2 Plug and Play Harness  (Read 9001 times)
Offline klopsdp
  • Newbie
« on: January 13 2016, 09:10:34 PM »
All the wires of the Gen2 intimidated me into buying Caspers plug and play harness for the Gen2.  Now, I'm stuck.  What has to be done to enable the plug and play harness to be used with a PLK wideband.  Also, is the stock ECM case large enough to accept both the Gen2 and Powerlogger?  Thanks.
Re: Caspers Gen2 Plug and Play Harness
« Reply #1 on: January 13 2016, 11:12:53 PM »
You probably need to get the instructions and see what the inputs are. I'm guessing the gen2 has some kind of input to hook up a wideband to help it know what is going on. You just have to figure out which wires it is.
« Reply #2 on: January 14 2016, 12:01:13 AM »
http://www.fullthrottletech.com/attachment.php?attachmentid=304&d=1151351332
Try this
Here are all the instructions.
http://www.fullthrottletech.com/forumdisplay.php?f=65
You can also hook up a laptop to the Gen ll and log some of the data with tuner pro
