Welcome to IHADAV8.com!
Always fun to make a see some results
Quote from: good2win22 on August 17 2016, 11:07:28 PMAlways fun to make a see some resultsTrue. But, I wasn't aiming for 11psi and nearly 100% duty cycle. This is a bit on the ragged edge for a 10.9:1 engine; 40% ethanol or not.I rescaled the MAF last night and richened up the Power Enrichment table in the higher RPMs; I will re-jet the propane to get more fuel flow (pretty sure it has a small jet in it right now?).
Quote from: motorhead on August 18 2016, 09:25:30 AMQuote from: good2win22 on August 17 2016, 11:07:28 PMAlways fun to make a see some resultsTrue. But, I wasn't aiming for 11psi and nearly 100% duty cycle. This is a bit on the ragged edge for a 10.9:1 engine; 40% ethanol or not.I rescaled the MAF last night and richened up the Power Enrichment table in the higher RPMs; I will re-jet the propane to get more fuel flow (pretty sure it has a small jet in it right now?).Goes to show my ignorance. I looked at your log and only saw the KR. It's going to be a really steep learning curve when I finally go to an SD chip
Why not go 2 bar SD Mike?Looks fun.
expected a different finger to be used to cover license place- out of character?
