Author Topic: How Fast Would It Go?  (Read 15161 times)
Re: How Fast Would It Go?
« Reply #30 on: December 19 2015, 04:23:24 PM »
thanks Brad for the offer!  Just over the counter timing sets?  I know you have your motor apart it seems like once a year, do you find they are wearing much after a season of use?  Sometimes info you read gets influenced so much by venders its hard to tell what myth from reality can be at times.
I've had this same timing set on the last engine...and I beat on it for 3 seasons. :rock:  I just transferred it to this engine...and it was still snug. I run stock junk...works just fine. I'll text Joe for a part number for a timing set for you. Lift the hood on my car...and you'll fall asleep from boredom. :)
I had the other engine out of the car numerous times. Overboosted it...never did find the headgaskets. :) Piston pin came loose...scored a cylinder. Had it sleeved. Cracked a cylinder...had it sleeved. Cracked another cylinder...and tossed the block. Went to my original engine in July of 2014. So far...so good. :) Dan and I can have my engine out and sitting on a stand in an hour. I'm not joking. :rock:
Offline xpander343
« Reply #31 on: December 20 2015, 01:50:47 PM »
thanks brad,  appreciate the part number when you get it.
87 Regal Limited
« Reply #32 on: December 20 2015, 03:38:08 PM »
I'm a vendors nitemare. The majority of the stock junk is incredibly durable. I've gone 6.7 with a stock bottom end and Bison cracked the 9's with a stock short block. Alan aka Turbobitt has broken into the 8's with a stock coil pack and ignition module if memory serves. The ones that forget the basics...are the ones who get in trouble. Laugh at my engine compartment all you want...but the car runs hard every pass. :) Money well spent...is in these transmissions. :)
« Reply #33 on: December 20 2015, 07:01:01 PM »
Couldn't agree more on beefing up the 200-4R.
Are you using the Cloyes timing set?  I get mine from Orielly's. cloyes part number 9-1134
Offline tb3
« Reply #34 on: December 20 2015, 07:20:55 PM »
kick ass!
you guys that make the most outta what is there are always the most interesting posters.
I think that is why I have always been a fan of Steve and earl
Offline 278CIKILLER
« Reply #35 on: December 20 2015, 08:15:02 PM »
Brother we have guy's up here that have 10 to 15 thousand dollars in there motor with the bolt on's and still run in 13s, Keep it simple. That's the way Brad keeps it.
« Reply #36 on: December 20 2015, 09:04:24 PM »
Just got off the phone with Joe. Cloyes it is.  :rock:
Offline xpander343
« Reply #37 on: December 21 2015, 12:49:34 PM »
cool thanks guys
87 Regal Limited
