Author Topic: Turbo Blanket Question  (Read 5838 times)
« on: December 13 2015, 07:29:35 PM »
Does a high quality turbo blanket...like one from DEI quicken spool time? It holds heat in...so in theory...it should. Anyone?
« Last Edit: December 13 2015, 07:56:24 PM by Scoobum »
Re: Turbo Blanket Question
« Reply #1 on: December 13 2015, 10:28:58 PM »
I'd like to hear thoughts on this as well.
« Reply #2 on: December 13 2015, 10:48:06 PM »
Why do Turbine's inject water into the turbine section and not the compressor section for more power? :chin:
« Reply #3 on: December 13 2015, 11:50:33 PM »
Like a gas turbine? I believe it reduces the amount of NOx in the exhaust
« Reply #4 on: December 13 2015, 11:52:29 PM »
I would guess more in theory than in practice
« Reply #5 on: December 15 2015, 10:20:01 PM »
My brother works on turbines for a living and he said water is injected to lower the temp and thereby lowering the emissions. Lower temp equals less NOx.
« Reply #6 on: December 16 2015, 07:31:15 AM »
I'd bet it does more to reduce underhood temps.
« Reply #7 on: December 16 2015, 07:52:37 AM »
I'm hoping to have a little research time today at work, so maybe I can find some scientific data to post on this subject.
Here's my thoughts on it.  If heat is what makes the turbine wheel spool it would lead me to believe that wrapping the heat source prior to entering the turbine housing is where the most benefit would come from.  If the heat can't dissipate as easily prior to entering the exhaust and then the hot gases are allowed to expand a bit while entering the exhaust housing then that would lead me to believe that it would work in our favor.... I don't know... I have heard the whole it will cause a fire arguement.
« Reply #8 on: December 16 2015, 08:37:55 AM »
Its best use is probably to prevent burning the paint off of the hood!
« Reply #9 on: December 16 2015, 10:18:51 AM »
Stop Peed nailed it!
« Reply #10 on: December 16 2015, 10:24:08 AM »
What I found this morning...
Wrapping exhaust originated in NASCAR
One fella claims he has data logs proving that with the wrap on pre-turbo, he spooled 150 RPM's earlier
Lots of fires reported with the wrap
Header manufacturers will not warranty their product if it's been wrapped.
It has a strange smell after installation
I think I like ceramic but how do you coat just the outside???
« Reply #11 on: December 16 2015, 11:21:26 AM »
My only experience with turbo blankets was a buddy put one on his new turbo performance difference was marginal if at all but the oil seal eventually let go just as the warranty expired on the turbo. Personally I think keeping all that heat in was part of the problem.  Might be good for a race car but I wouldn't use one on a street car.
This was a brand new name brand turbo and they did not warranty it he only put about a thousand miles on it and no track time.
« Reply #12 on: December 16 2015, 03:27:36 PM »
I would just coat the inside. No sense in heating the casting when you can keep the heat in there and working on the exhaust gases.
When were turbos allowed in NASCAR?
« Reply #13 on: December 16 2015, 03:54:29 PM »
The idea of wrapping exhaust originated in the NASCAR scene. Somebody got the idea from them and carried it onto the street scene
« Reply #14 on: December 16 2015, 05:12:40 PM »
That's what she said!   :rock:
