Author Topic: money to spend  (Read 8194 times)
money to spend
« on: December 07 2015, 09:02:48 PM »
Got some money I can put into car!! :icon_lol:  So what I want to do is upgrade and quiet down the valvetrain. I have owned many Gm 3800's and they all have been such quiet motors. I want this one to be the same. With my new convertor it has made a noisy motor even worse. What is a good combo of cam and rockers that will make good power and also be QUIET. As always, thanks for any help
Re: money to spend
« Reply #1 on: December 07 2015, 09:13:25 PM »
Swap in a 3800.  Seriously.
I am thinking of putting a LFX in my MCSS with a turbo. ;)
Re: money to spend
« Reply #2 on: December 07 2015, 09:36:02 PM »
Not that much to spend :O
Re: money to spend
« Reply #3 on: December 07 2015, 09:44:43 PM »
Mike at FT sells the complete roller cam kit. You have a choice between HS and TA rockers...stay with the 1.55 ratio.
Re: money to spend
« Reply #4 on: December 08 2015, 07:58:24 AM »
Call up Cam Motion and see if Kip can grind you a cam with modern smooth ramp rate lobes.  The LS world is moving toward civil valvetrain characteristic s to beat the sewing machine noise produced by older lobe designs.
Offline williambavila
Re: money to spend
« Reply #5 on: December 08 2015, 09:25:54 AM »
I am running Full throttles full roller kit and Harland sharp rockers. The whole thing is quiet, as for a converter call dusty @ 256-303-5387 you cannot go wrong. if your in need of head gaskets or intake gaskets let me know I have everything in stock fairly cheap or trade for some goodies. What turbo and injectors are you runnin? I have a set of 60# ones for sale.
Re: money to spend
« Reply #6 on: December 08 2015, 11:17:28 AM »
What size is your cam?  And when you say quiet, do you mean a faint tick?  Also, what is your pre-load set at?  Mine is 0.035 and it is fairly noticiable but I do have the more noisy comp lifters.
Re: money to spend
« Reply #7 on: December 08 2015, 11:54:25 AM »
I always thought it was the link bars that was part of the noise you hear.
Re: money to spend
« Reply #8 on: December 08 2015, 01:21:33 PM »
Ya quiet is the priority for me! I have a new silverado and its noisier than the good ol 3800's. Probably the water thin oil they want ya to run......hate a "ticky" motor....sound s junky to me
money to spend
« Reply #9 on: December 08 2015, 01:39:03 PM »
My buddy's car has a flat tappet cam its quiet
« Last Edit: December 08 2015, 01:45:42 PM by larrym »
Offline gusszgs
  • Limited quick brick
Re: money to spend
« Reply #10 on: December 08 2015, 05:28:34 PM »
The forged slugs tend to slap around when cold.......... nature of the beast
Jim
1987 T Limited
money to spend
« Reply #11 on: December 08 2015, 05:52:30 PM »
There was a thread on the other board where guys have used the series ll lifters and dog bone retainers to eliminate the need for the link bar lifters.
Re: money to spend
« Reply #12 on: December 08 2015, 07:05:16 PM »
Looks like a full roller setup runs about $1600. Question is will it be ticky?  Interested in this series II thread? They are a very quiet motor. Any specific info on the parts for that switch....if its possible?
Re: money to spend
« Reply #14 on: December 08 2015, 09:49:14 PM »
This was just posted.
http://www.turbobuick.com/forums/threads/parting-engine-3-roller-cam-with-lifters-timing-cover.435097/#post-3617108
You and I need to talk to Bison about grinding a cam for these engines we're building. :) I'm calling him over the holidays. :powersix:
