The Bastard Child Buick Board
General
IHADAV8 Playground
My winter or many winters project
Pages:
2
3
4
5
Topic: My winter or many winters project (Read 15901 times)
larrym
PSI: 1
Reply #45 on:
December 06 2015, 11:35:01 PM »
Helwig is a different desgn it bolts to the diff and has end links that bolt to the cross member.
Last Edit: December 06 2015, 11:41:25 PM by larrym
good2win22
Re: My winter or many winters project
Reply #46 on:
December 07 2015, 08:17:26 AM »
Hey Rich,
The problem with that bar is it is still bolted to the lower control arms. Hellwig and the HR bar clamp to the axle tubes and then to the frame. When installed and adjusted properly it really helps straighten the car out
larrym
PSI: 1
Reply #47 on:
December 07 2015, 08:53:52 AM »
Car drives much better with it and it's adjustable 3 settings plus you can preload the PS so no air bag is required
larrym
PSI: 1
Reply #48 on:
December 09 2015, 09:35:01 PM »
Got a little more done almost time for paint.
larrym
PSI: 1
Reply #49 on:
December 12 2015, 02:51:13 PM »
A coat of POR15 flip it over do the top and run some lines.
Scoobum
Reply #50 on:
December 12 2015, 04:36:50 PM »
Looks good.
good2win22
Reply #51 on:
December 12 2015, 10:15:01 PM »
Nice!
Pyro6
PSI: 2
Reply #52 on:
December 15 2015, 04:47:01 PM »
Lookin good
larrym
PSI: 1
Reply #53 on:
December 20 2015, 04:40:25 PM »
So got the frame finished of found the PS cross member mount needed a little help I had left it on while I was welding it up.
I cut a piece of plate and slide it under I attached it to the material I boxed the frame with for added support.
larrym
PSI: 1
Reply #54 on:
December 20 2015, 04:44:15 PM »
Started to work on the floor the little hole under the window was more than I thought....
Cut it back and fit a piece of 18 ga sheet metal.
good2win22
Reply #55 on:
December 20 2015, 06:56:12 PM »
Progress!
Be4u
Reply #56 on:
December 21 2015, 04:04:17 AM »
Great thread!
Save the bumper fillers!
Move to Canadia!
larrym
PSI: 1
Reply #57 on:
December 29 2015, 02:00:05 PM »
I made a patch panel for the floor and patched the hole by the seat belt mount.
The body mount is going to take some fabrication...
Scoobum
Reply #58 on:
December 29 2015, 02:39:36 PM »
Lookin' good! Keep the pics comin'!
larrym
PSI: 1
Reply #59 on:
January 02 2016, 08:08:42 PM »
Ok remember I'm not a welder fabricator....
Patched the floor and made a channel would have welded it in but my hole saw was not up to the challenge.
Pages:
2
3
4
5
General
IHADAV8 Playground
