Author Topic: My winter or many winters project  (Read 16304 times)
« Reply #30 on: November 27 2015, 11:17:13 PM »
So I was thinking of using these rather than bracing the stock LCA bracket.
https://wildridesracecars.com/shop/general-motors/g-box-lower-replacement/
Re: My winter or many winters project
« Reply #31 on: November 27 2015, 11:35:35 PM »
You could make those and save yourself about a hundred bucks
« Reply #32 on: November 27 2015, 11:49:15 PM »
I did consider that option wonder if my fab skills are up to it look simple enough.
« Reply #33 on: November 28 2015, 12:25:23 AM »
Those will really give you some options on setting the LCA level depending in your ride height.  Take a look at http://www.baselinesuspensions.com/kits/chevy.htm for the upper bracket ideas. Lots of options with their brackets as well
« Reply #34 on: November 28 2015, 12:49:39 AM »
Cool thanks!
« Reply #35 on: November 28 2015, 04:03:24 PM »
Chanel all boxed.
« Reply #36 on: November 28 2015, 05:46:40 PM »
And here is why.... It would lift 1 side 8" before the other side came off the jack stand.
https://vimeo.com/147856167
« Last Edit: December 04 2015, 10:39:26 AM by larrym »
« Reply #37 on: December 04 2015, 10:36:54 AM »
LCA braced decided to keep it simple.
« Reply #38 on: December 05 2015, 01:55:03 PM »
Wow, Jason that page is LOOOAADDDED(in my best ron white voice)with info. Thanks for posting it. I have to get bus0y measuring so mine can 60' like some of those.
« Reply #39 on: December 06 2015, 08:06:23 AM »
I used there upper relocation brackets and upper arms in the white T. Helped me center the rear axle under the car and dial in the preload on the right rear tire.  I had MT streets on the car and had a best 60' of 1.59. I plan on putting the same upper brackets and arms on the limited along with a hellwig bar and some 28x9 slicks.  First things first... Will be a moser axle swap.  I'm looking at their 30 spline axles and posi
« Reply #40 on: December 06 2015, 09:05:13 AM »
I couldn't get to their site where they sold stuff. The link at their page was dead. I'll have to look into it.
« Reply #41 on: December 06 2015, 03:39:58 PM »
Helwig ARB is worth buying the links are a little hokey I had a problem with one they had me a replacement in 3 days no charge no questions.
« Reply #42 on: December 06 2015, 07:26:51 PM »
Your welding is looking good. :)
« Reply #43 on: December 06 2015, 09:04:58 PM »
Thanks Brad it's easier every pass 😃
« Reply #44 on: December 06 2015, 10:25:43 PM »
http://www.aggressiveauto.com/proddetail.asp?prod=SU00
I'm wanting one of these. How big is the helwig bar?
And box the control arms.
