Author Topic: HP Ratings on 84/85 blocks.  (Read 4139 times)
Offline 278CIKILLER
« on: November 04 2015, 09:33:22 PM »
Just asking what's the HP ratings for a 84/85 G/N blocks. Whats the lowest ET have they gone thank's
Offline williambavila
Re: HP Ratings on 84/85 blocks.
« Reply #1 on: November 05 2015, 12:56:49 PM »
are you asking how fast a hot air car has gone or are you asking how fast a car has gone with a hot air block? I would have no issue running a hot air block they are the same minus the oil drain for the turbo
« Reply #2 on: November 05 2015, 01:27:14 PM »
There are some other minor differences around the oil drainback holes and such...but, far as I know, the casting is similar.
« Reply #3 on: November 05 2015, 03:48:15 PM »
The casting is similar.
Which we had smart phones 20 years ago. I would have had pictures of this stuff. I'm thinking the webbing in the valley wasn't the same.
For a mid 11 second car or a back up engine, why not  :powersix:
Offline 278CIKILLER
« Reply #4 on: November 05 2015, 06:10:22 PM »
the casting number is 2554290, from what i have read is they were a test motor back then, I was just wondering how far could you take the block? mid 10s?
Offline tb3
« Reply #5 on: November 05 2015, 09:40:20 PM »
you can take a hot air block just as fast as a 109 block.
deck height is different. but only a matter of thousanths.
as mentioned above, the valley webbing is viisably  differant. the hot ai/na blocks have a more "porous" valley casting, while the 109s are a  more definetive cast.
I have not ever seen any proof of the pre-109s being weaker than the 109s.
Offline 278CIKILLER
« Reply #6 on: November 05 2015, 10:17:10 PM »
That's great and thank's, I really luck out on this motor that's for sure.
« Reply #7 on: November 05 2015, 11:03:55 PM »
Looks like it is out of an '84 non turbo car.  I would take some sanding rolls and get rid of any casting flash to try to remove any potential stress cracks and give it a shot
Offline 278CIKILLER
« Reply #8 on: November 05 2015, 11:10:19 PM »
The gentlemen i got this from was given a 87 G/N and this motor, it's set up with a cam sensor oil feed block on the side the same thing just like a 87 motor.
