Author Topic: Plenum Volume-How Important? Any Gains?  (Read 2541 times)
« on: November 02 2015, 05:22:14 PM »
Are there any gains to be had by adding plenum volume via a spacer? If so...why?
Re: Plenum Volume-How Important? Any Gains?
« Reply #1 on: November 02 2015, 07:39:00 PM »
Lawrence Conley said there was.  Others disagreed.  He was the quickest guy around for a long time.
The idea was to stabilize the air and reduce turbulence so that the air would make a smoother turn into the heads which should help in equalizing air cylinder by cylinder.
More recently, the Hemco was reborn with guys  claiming it would do the trick better.  Remember that I gave one to ttipe to play with as he was following the lead of Red, and, I think, the zddp+ guy....have not heard any results in quite awhile.
« Reply #2 on: November 02 2015, 08:03:00 PM »
Hemco bitch!  Sorry, I couldn't help it.
« Reply #3 on: November 02 2015, 08:16:38 PM »
lol
« Reply #4 on: November 02 2015, 09:19:10 PM »
Yep, it had to be said. Pretty funny too.
« Reply #5 on: November 03 2015, 02:50:25 AM »
I run a 3/4" Champion spacer.
