Author Topic: New rear end  (Read 2605 times)
Offline TurboCajun
  • Keith Theriot
  • 6 Packed
New rear end
« on: October 22 2015, 09:20:10 AM »
I ordered a new rear end for my car, It's a 9" with disc brakes from Checkered Racing. their web site says that it weighs 160lbs, anyone know what the factory unit weights are ?
Re: New rear end
« Reply #1 on: October 22 2015, 10:40:28 AM »
Don't know, but I think somewhat less than that as I don't remember them being hard to move.  :D
Re: New rear end
« Reply #2 on: October 22 2015, 11:57:16 AM »
I've got a 9" and the stock 8.5" here. I can pick up the 8' easily but the 9" is a struggle for me. That's empty, so they weigh a bunch more than stock. Cancel it and order a 12 bolt. You'll be much happier in the end.
New rear end
« Reply #3 on: October 22 2015, 12:31:16 PM »
My buddy had 9" ends welded on with custom axles it's working good.
