Nasty Wendy Isn't
engine tick........help
Pages:
2
3
4
5
6
Topic: engine tick........help (Read 24716 times)
Reply #45 on:
October 26 2015, 08:22:16 PM »
Did the rpm drop less on any cylinder?
Shimy87
PSI: 2
Re: engine tick........help
Reply #46 on:
October 26 2015, 08:34:27 PM »
No......same sound with each one removed
Reply #47 on:
October 26 2015, 08:41:43 PM »
And the rpm drop was similar on each cylinder?
Shimy87
PSI: 2
Reply #48 on:
October 26 2015, 08:46:40 PM »
Yes
Scoobum
Reply #49 on:
October 26 2015, 08:51:45 PM »
Chris Garrett has a new screen name? Sorry Steve...couldn't resist.
Reply #50 on:
October 26 2015, 08:58:11 PM »
So crank it up, turn out the lights, and look around under the hood to see if you see any sparks jumping to ground
Shimy87
PSI: 2
Reply #51 on:
October 26 2015, 09:09:56 PM »
Just checked...blac
k as night, no sparks.
Reply #52 on:
October 26 2015, 09:23:15 PM »
Damn....get a stethoscope and try to narrow an area down as was suggested. It might be lifter, I guess.
Check the front cover to see if the noise is coming out of there as on the tensioner as mentioned
Shimy87
PSI: 2
Reply #53 on:
October 26 2015, 09:41:19 PM »
I will get one tomorrow and check around......wo
uldnt a lifter, pushrod, bad cam lobe still be easy to hear in park. Seems you need to have a load on motor to get a tick?
I dont understand it
Reply #54 on:
October 26 2015, 10:00:07 PM »
well, again, maybe....I thought maybe it was a piston pin, but that usually diminishes when you disconnect the injector on that cylinder. Assuming the oil pressure is good, ticking lifters often disappear when the rpm comes up. If the lobe is bad, or the pushrod bent, I would have expected less rpm drop on the cylinder affected. #3 exhaust is usually the lobe that goes bad, but not always.
larrym
PSI: 1
Reply #55 on:
October 26 2015, 10:06:24 PM »
what is the oil pressure?
Shimy87
PSI: 2
Reply #56 on:
October 26 2015, 10:09:01 PM »
Warm its 25ish at idle. 50 when crusing.
Reply #57 on:
October 26 2015, 10:20:09 PM »
You have not been manually shifting the car when you were running it, have you?
Shimy87
PSI: 2
Reply #58 on:
October 26 2015, 10:22:39 PM »
Nope....and racing I put it in drive, not overdrive
larrym
PSI: 1
Reply #59 on:
October 26 2015, 10:32:58 PM »
is the sound louder in the car than out? have you inspected the flex plate?
Pages:
2
3
4
5
6
