Author Topic: engine tick........help  (Read 24692 times)
Offline williambavila
Re: engine tick........help
« Reply #30 on: October 26 2015, 09:55:55 AM »
 :068: :powersix:  buick problems
« Reply #31 on: October 26 2015, 10:12:33 AM »
Gotta love them!
« Reply #32 on: October 26 2015, 11:14:56 AM »
I hope to be able to do the injector test tonight. On the BLM's i'll check that also, I think they are usually 118, I know they are supposed to be 128. So what is Brad thinking??
« Reply #33 on: October 26 2015, 11:49:10 AM »
118 means it's pulling fuel. I think Brad was thinking it would be high adding fuel which would indicate an exhaust leak
« Reply #34 on: October 26 2015, 12:03:06 PM »
Don't know how many times I have poured some top engine cleaner into one and had a cloud of smoke come up from around the turbo or from the headers or down pipe...from cars that had supposedly no leaks....oh, well, on to the injector disconnecting
« Reply #35 on: October 26 2015, 06:21:39 PM »
I was looking for an easy way out. Shimy...leave it fat...you'll get a smoother idle. 128 is over rated. :)
I watched Norbs adjusting the idle fuel on his S1 engine. When he leaned it out it idled like crap...and when he fattened it up...it purred like a kitten...and it had a cam the size of King Kong in that engine. The ECM will compensate for fueling. Steve can explain it in detail. My engines have always come in around 117-118.
« Last Edit: October 26 2015, 06:30:16 PM by Scoobum »
« Reply #36 on: October 26 2015, 06:31:20 PM »
Blm warm idle at 124. As before in park hard to hear tick but tried each injector at various rpm and no real difference made. Drive car and you hear the tick. In park reving motor hard to replicate noise. What in drive train would sound like a lifter tick. If it ticks when driving it should tick in park if its the valve train.....I would think....but as noticable as it is when driving its impossible to make it happen in park in garage. ?????? Making me crazy!!!!!
« Reply #37 on: October 26 2015, 06:39:02 PM »
Spark plug wire arcing?
« Reply #38 on: October 26 2015, 06:48:30 PM »
 Shimy...can you get a brave soul to stick his head under the hood and listen while you put it up against the foot brake? Sounds like it's doing it under load.
Offline gusszgs
  • Limited quick brick
« Reply #39 on: October 26 2015, 06:56:48 PM »
Sounds like an exhaust tick, get another guy to listen while you do like Brad said. Usually really hear this clearly under load going over bridge/tunnel where where you have the 2 concrete walls to rebound that lovely sound
Jim
1987 T Limited
« Reply #40 on: October 26 2015, 07:17:04 PM »
I will try it tomorrow. It keeps coming back to an exhaust leak. I cant count all the time ive spent checking with sea foam ( with no visable leaks) replacing exhaust gaskets, looking for cracks, adjusting connections slowly....if its an  exhaust leak its the sneakyist frickin leak in history!!
« Reply #41 on: October 26 2015, 07:45:40 PM »
Did you kill the injectors as I asked?
« Reply #42 on: October 26 2015, 07:48:02 PM »
Grab a stethoscope at the parts store it's my favorite tool. I use the metal rod to listen for engine noise than I add a t fitting and a large vacuum line for exhaust and vacuum leaks makes it easy to pin point problems.
« Reply #43 on: October 26 2015, 07:51:08 PM »
yes....see above for detailed report
« Reply #44 on: October 26 2015, 08:20:38 PM »
So the tick did not lessen when any injector was disconnected?
