The Bastard Child Buick Board
engine tick........help
Pages:
2
3
4
6
Topic: engine tick........help (Read 24693 times)
Shimy87
PSI: 2
Re: engine tick........help
Reply #15 on:
October 24 2015, 04:24:50 PM »
Varys with throttle....so
unds exactly like a lifter that need adjustment....
.I know there is no adjustment on these but I really want to get rid of this....makes the car sound junky
Reply #16 on:
October 24 2015, 07:14:08 PM »
Do you hear it with the belt removed?
Shimy87
PSI: 2
Reply #17 on:
October 24 2015, 09:37:57 PM »
Just tried it......yup
Reply #18 on:
October 24 2015, 09:48:28 PM »
Does it go away when the engine warms up?
good2win22
Reply #19 on:
October 24 2015, 09:59:04 PM »
Have you listened down by the crank sensor? Might be loose and making contact with the reluctor on the back of the balancer
Shimy87
PSI: 2
Reply #20 on:
October 24 2015, 10:38:01 PM »
Dosent go away when warm. Ill check crank sensor. Its not obvious when in park and you rev it, you can hear It though, but driving its very easy to hear.
Reply #21 on:
October 24 2015, 10:54:11 PM »
get some one to rev the engine while you lay on the floor and watch the balancer for movement
Also listen to each injector to see if one is making noise=more than usual
Shimy87
PSI: 2
Reply #22 on:
October 25 2015, 10:44:22 AM »
Balancer is tight no wobble with rpm change and touches nothing. Injectors all click a little but pretty consistant, none loud enough to hear inside car.
Reply #23 on:
October 25 2015, 12:05:41 PM »
I might warm the car up and let it idle...then pull one injector harness connector at a time off and see if the click diminishes on any given cylinder...of course replacing each removed connector before going to the next
Scoobum
Reply #24 on:
October 25 2015, 09:09:11 PM »
What's the BLM count in park with the engine warmed up. Don't ask why I'm asking.
Reply #25 on:
October 25 2015, 09:38:52 PM »
Lol
good2win22
Reply #26 on:
October 25 2015, 10:41:09 PM »
Hey Steve, I'm thinking outside the box here but could the timing tensioner be the culprit here?
Reply #27 on:
October 25 2015, 10:45:11 PM »
Maybe...
larrym
PSI: 1
Reply #28 on:
October 25 2015, 11:31:40 PM »
Crank end play?
Reply #29 on:
October 26 2015, 12:06:30 AM »
He said the balancer was not wobbling or moving...
My first guess is what Brad is thinking. My second is lifter/cam problem...
Pages:
2
3
4
6
