Author Topic: exhaust tick  (Read 2299 times)
exhaust tick
« on: October 19 2015, 07:47:48 PM »
Back to this one. Seems most like to not use gaskets. What's an effective way to true up manifold surface in a DIY manner?
Re: exhaust tick
« Reply #1 on: October 19 2015, 08:12:13 PM »
Leave the front and rear header bolts in...remove the others. The header gaskets will drop in. Reinstall the bolts and cinch them up via the proper torque sequence.
Re: exhaust tick
« Reply #2 on: October 19 2015, 08:29:29 PM »
Dan and I had a DS header warped to fuck a couple years back. Sent it out to have it machined...and it was still a mess. Our solution was to cut it to relieve the stress. No more leak.
Offline gusszgs
  • Limited quick brick
Re: exhaust tick
« Reply #3 on: October 20 2015, 06:21:23 PM »
I had the typical DS header 3-5 crack.....weld ed it up with a gusset for support. Flange got warped during the welding so I took it to a reputable machine/welding shop and they machined it laser straight. No gasket no leaks
Jim
1987 T Limited
Re: exhaust tick
« Reply #4 on: October 20 2015, 07:02:37 PM »
Tore the bitch apart tonight, drivers side no cracks, no leaks. Had to take the down pipe out to drop out the x over pipe. Found 2 leaks where it connects to the passenger side header. Appears where they flared the header for the joint they left a bit of a ridge and I think that might have caused it? Filed it down to a nice smooth socket again and will put back together tomorrow. Should I use high temp silicone at these joints?
