Author Topic: torque spec pan bolts  (Read 4950 times)
« on: October 15 2015, 01:14:52 PM »
Whats the spec for pan bolts...rubber gasket....than ks guys
Re: torque spec pan bolts
« Reply #1 on: October 15 2015, 01:22:13 PM »
88 inch pounds.  You may want to retork after a heat cycle.  Good luck getting that torque wrench back up there after the heat cycles.  Some gaskets have a metal sleeve to keep you from squishing the gasket.  I don't recall the brand or part number.  Maybe one of the smart guys knows...
« Reply #2 on: October 15 2015, 07:09:00 PM »
transmission pan or oil pan?
transmission pan is 120-150 lbs-inch (not lbs-ft!}
« Last Edit: October 15 2015, 07:42:38 PM by Steve Wood »
