Author Topic: Track results with my Limited  (Read 64187 times)
Offline gusszgs
  • Limited quick brick
Re: Track results with my Limited
« Reply #75 on: June 29 2016, 07:23:16 PM »
Silly question, is there a converter still in the exhaust?
Take all the air out of the bag and pull more first gear fuel. By the time your mixture catches up to the boost, it starts to make decent power. Before that, it's too rich / can't burn what's there. That's why boost comes up/blows the tires off a few feet out.
I used to run 115 mph on a little 49 and stock cam. Stock everything in the rear. 26' D/R. 11.8's all day.
No cat, 20% fuel removed from 1st stock cam as well 180k on the clock......... .how much timing and boost we you running on the "little 49" what was your 60'? The car ran 111 back peddling outta the gate twice 2.1 60' 90* heat.
Jim
1987 T Limited
« Reply #76 on: June 29 2016, 07:36:28 PM »
I bet he was close to 30psi. I do think you need more boost with that alcohol.
Offline gusszgs
« Reply #77 on: June 29 2016, 08:20:00 PM »
And here I thought I was doing a good thing adding the "cool guy" 90/10's  :cool;
Ah well, sometimes the road to hell is paved with good "cool guy" intentions
We'll keep plugging away.........t his is supposed to be fun right  :O
Jim
1987 T Limited
« Reply #78 on: June 29 2016, 09:13:03 PM »
Next up for Jim is tuning in the turn on point for the alky...which will take up an entire track session. :)
« Reply #79 on: June 30 2016, 08:30:56 AM »
Oh, this is fun, and lots of it.  :D if it was easy we'd all be running in the 10s
« Reply #80 on: June 30 2016, 09:20:24 AM »
It is easy, and, we would all be running tens if we had money and common sense
« Reply #81 on: June 30 2016, 09:21:08 AM »
Jim, what are the compression readings on your engine?
« Reply #82 on: June 30 2016, 09:48:52 AM »
And here I sit, short on both counts. All good though, I keep trying to learn from the info posted.
« Reply #83 on: June 30 2016, 10:24:52 AM »
Don't feel bad, I seem to be short of both lol
« Reply #84 on: June 30 2016, 10:34:17 AM »
Me three!
Offline 1 RARE T
« Reply #85 on: June 30 2016, 11:58:31 AM »
Spraying alky with 24psi. Pump gas.
 If I managed a 1.6 off the foot-brake,  :rock: Most were 1.7-8.
Mine liked fuel in the last 1/8. I ran it at 11 ish Air/fuel ratio and it gained the most. Every car is different.
FYI, it hooked the best with the DR's with less than 20 psi in them.
« Reply #86 on: June 30 2016, 12:31:31 PM »
Me also....I read all I can and doing what I can as cheaply as I can. Mines much more of a show car than a race car. Racing is much more fun than waxing :icon_lol:
Offline gusszgs
« Reply #87 on: June 30 2016, 01:26:47 PM »
Steve, I have them written down in a book I have. I did this when I first purchased the car in '07 I think. I'll have a look tonight when I get home from work. 145 range seems to ring a bell but the Alzheimer's is setting in so I maybe off. I do remember all 6 were nice and close % wise.
Actually, you got me thinking, I should do a check again anyway.
Jim
1987 T Limited
« Reply #88 on: June 30 2016, 02:03:30 PM »
If they are all nice and even %wise, but they are 130 psi on average, the engine is tired and not giving you the opportunity to make the power it should...Far too often I get mail from guys that have the latest and greatest of everything and their car is a dog.  How often have I finally found out the car has a weak cylinder, or tired valve springs, or something else basic.
It's always good to check the basic foundation before worrying about the lipstick :)
Offline reality
« Reply #89 on: June 30 2016, 03:51:55 PM »
 Are you speaking of personal experience Steve.
Paul Hogan comes to mind.
