Author Topic: Track results with my Limited  (Read 64189 times)
Re: Track results with my Limited
« Reply #105 on: August 28 2016, 01:00:47 PM »
Sweet.
« Reply #106 on: August 28 2016, 01:31:24 PM »
Nice work!
Mobile larrym
« Reply #107 on: August 28 2016, 01:31:42 PM »
Nice :rock:
Offline gusszgs
  • Limited quick brick
« Reply #108 on: August 28 2016, 01:58:07 PM »
Thank you gents!
Jim
1987 T Limited
« Reply #109 on: August 28 2016, 02:41:32 PM »
Nice run! :)
Got a log of it?
« Reply #110 on: August 28 2016, 02:54:02 PM »
Nice run. Jim...don't go back until the air gets better. What was the 1/8th MPH and the ET? Post the log if you can. RPM at the traps?
Offline gusszgs
« Reply #111 on: August 28 2016, 04:42:26 PM »
Well I tried to post the log, but I guess I doesn't work.
It's linked with my update post.
Jim
1987 T Limited
Offline gusszgs
« Reply #112 on: August 28 2016, 04:55:06 PM »
Thanks, the 1/8 mph was 92.5 et was 7.48
Trap rpm was approx 5500
« Last Edit: September 03 2016, 09:31:28 AM by gusszgs »
Jim
1987 T Limited
Offline gusszgs
« Reply #113 on: August 28 2016, 04:56:54 PM »
Nice run! :)
Got a log of it?
Yes Steve I do but I guess it didn't work it's in my first post of today
Jim
1987 T Limited
« Reply #114 on: August 28 2016, 05:02:04 PM »
You can fire it off to my e-mail if you want.
Offline gusszgs
« Reply #115 on: August 28 2016, 05:09:32 PM »
Done!
Jim
1987 T Limited
« Reply #116 on: August 28 2016, 05:13:14 PM »
Convertor slip checks in at 14.75 percent. I don't know whether you can lock Davids convertor. Depending on your high gear fueling...and if it's rich...you could lean it out to make a tad more HP. If you're MPH doesn't come up...then you're likely 'blowing through' it. I'd wait for the cool/dry air to get here...toss a 28" rear tire on it...and have at it. I have 28" DR's mounted on GN rims. You're welcome to try them. I also have 10.5x28's mounted on GN rims...yours for the asking.
Offline gusszgs
« Reply #117 on: August 28 2016, 05:14:45 PM »
May this will work. Please forgive my lack of computer skills
Jim
1987 T Limited
« Reply #118 on: August 28 2016, 05:25:57 PM »
No one is lacking computer skills more than I am.
« Reply #119 on: August 28 2016, 05:40:17 PM »
Both low and high gear can have some fuel pulled. Battery voltage is below 13...but not showing KR. October air and a 1.6x launch should garner an 11.4x. Your 02's will drop sharply.
