Author Topic: trans temp sensor  (Read 14665 times)
Re: trans temp sensor
« Reply #15 on: October 17 2015, 07:41:55 PM »
Got her done, rev's much quicker, just did mellow test drive, so far really like it, builds boost so much quicker!! Maybe tomorrow ill have time to go try a few boosted launches and see what happens. Thanks for all the help guys :cheers:
« Reply #16 on: October 17 2015, 09:36:35 PM »
It'll be like letting loose an animal...
« Reply #17 on: October 17 2015, 09:49:18 PM »
next you will be goofing with the rear brakes to hold a decent boost pressure to launch. Ive seen this before. :icon_mrgreen:
« Reply #18 on: October 21 2015, 06:59:10 PM »
Holy cow took it out today working on exhaust leak. Brakes will hold 5 lbs. Boost......... .never left such a long burnout!!!!!!!!!!!!! Even a launch from idle, car rolls out about 2-3 feet and then just roast the tires. Tried a launch with 1 lb and again, smoke show. Will need drag radials for track next year.......lov e it  :rock: my 60 ft times have to get better now with some practice.
« Reply #19 on: October 22 2015, 05:59:39 AM »
This little stuff explains why even though stock, some are faster than others.
