Author Topic: trans temp sensor  (Read 14666 times)
trans temp sensor
« on: October 13 2015, 10:59:58 AM »
Does it make a difference if I put the sensor in the lower or upper location on the lines that go to the cooler from the tranny.
Re: trans temp sensor
« Reply #1 on: October 13 2015, 11:07:57 AM »
The one coming back will be cooler, or at least that is the theory.  I think I would want it in the before the cooler or hotter line. I'd have to look and see which one that is as I don't know right of hand.
If it is an electric gauge you could get another sender and run em both with a switch and see how well the cooler is working.
« Reply #3 on: October 13 2015, 12:47:41 PM »
Thanks!!!    :cheers:
« Reply #4 on: October 13 2015, 07:10:55 PM »
Got the tranny out this afternoon..... bell housing bolts were a bitch, don't know how I'll get those back in, specifically the pass side top one. Also there is a unconnected ground strap hanging at the top, I assume that belongs on the drivers side top bolt and someone previously didn't put it back.
Stupid question time, can I flip the tranny over to remove the pan and replace filter? Assuming I can but figured id ask?
Thanks!!!
« Reply #5 on: October 13 2015, 08:34:48 PM »
While the trans is out take a bfh and fold down the pinch weld on the trans tunnel. The belt housing bolts will be much easier then.
« Reply #6 on: October 13 2015, 08:41:29 PM »
I use a swivel socket for the bellhousing bolts...and a super long extension. Air ratchet makes life easy.
« Reply #7 on: October 13 2015, 08:48:36 PM »
x2 me too way easier from below.
« Reply #8 on: October 13 2015, 08:59:04 PM »
Yeah I had to use my 2 longest extensions together to get them. Will be buying one long one for installation. Can I flip the tranny to take off pan and change filter? Would be easier but dont know if that would screw up anything....pr obably stupid question :icon_redface:
« Reply #9 on: October 13 2015, 09:03:56 PM »
Get the fluid out or it will exit the vent when you turn it over.
« Reply #10 on: October 13 2015, 09:11:54 PM »
Its all drained...than ks !!
« Reply #11 on: October 13 2015, 09:33:52 PM »
Buy a long wobble extension and you can get to the upper bolts from the bottom.  Reinstall that ground strap.
« Reply #12 on: October 13 2015, 10:10:18 PM »
Big bump for Steve and installing the ground strap.  You can't have too may of those
« Reply #13 on: October 14 2015, 10:09:43 AM »
Are all brands of Dex VI the same? Price ranges by a couple bucks so if so I'll get cheapest
trans temp sensor
« Reply #14 on: October 14 2015, 11:13:12 AM »
I use the moble1 from Walmart 😜
