Author Topic: ATF choice  (Read 5837 times)
ATF choice
« on: October 12 2015, 12:59:15 PM »
What the best option for fluid?
ATF choice
« Reply #1 on: October 12 2015, 01:53:44 PM »
I use dex6 works good for me. But like motor oil there many opinions  on what is "best"
Re: ATF choice
« Reply #2 on: October 12 2015, 03:47:53 PM »
I use type f on the stock trannys. Read that it doesn't foam up like the dexron.  No issues with it and after a few filter changes it will be mostly all type F.  Think I read that on the spring cleaning list at gnttype website.
After having a high end built up tranny done, that guy recommended John Deere low viscosity hy-guard and one quart of something red so you can read the dipstick. That tranny has been beat on pretty hard with no issues.
I almost didn't want to post on this subject as everyone will have a say on what's best.  I can only tell you what I use
Re: ATF choice
« Reply #3 on: October 12 2015, 07:42:01 PM »
I use tractor fluid too. Coastal brand I got in a five gallon green pail. It is multiviscosity . It has been in there a year so far. Seems to be working well.
ATF choice
« Reply #4 on: October 12 2015, 10:40:59 PM »
With the heavier viscosity tractor fluid have you noticed any difference in the converter?
Lower brake and flash stall?
Re: ATF choice
« Reply #5 on: October 13 2015, 10:14:02 AM »
I didn't have anything to compare it too as this is a fresh 2004r and new converter and we took out the 700r4. I like what it is. It doesn't smell brunt or anything after a year.
