The Bastard Child Buick Board
ENGINE Stock unopened 3.8L SFI V6 longblock Modified stock S/S tubular headers Ported front timing cover Sealed Power high volume/high pressure oil pump w/ booster plate Roller cam button Viton valve seals Comp Cams 980-12 valvesprings RJC Power Plate HKS SSQV Blow off valve Speed Pro double roller timing chain LT1 mini-starter HRpartsNstuff driver's side motor mount K&N valve cover breathers TURBO & INTERCOOLER T-bolt hose clamps & heavy duty silicone couplers Garrett T63e turbocharger w/ heady duty adjustable wastegate 4" Turbo inlet pipe 12" Long K&N cone air filter w/4" inlet Front mount intercooler w/ custom fit 2.5" aluminum charge pipes IGNITION 8.5mm MSD SuperConductor sparkplug wires Stock ignition module Stock ignition coil FUEL SYSTEM Modified factory fuel hanger w/ATR dual high pressure fuel pumps Modified stock fuel rail for -10AN fitting Seimens 83pph injectors (6) Braided S/S Fuel lines -10 AN & -8 AN SX Performance billet adjustable fuel pressure regulator OGS Propain injection system (propane) SMC alcohol injection system EXHAUST 3" Mease Performance Engineering downpipe (internal wastegate) 4" custom S/S exhaust system w/ Magnaflow race muffler ENGINE MANAGEMENT MAFT Pro speed density conversion Extender Pro custom PROM (chip) Modified stock ECM for Low-Z injector drivers EGT signal converter High boost solenoid Fuel pressure transducer Oil pressure transducer GM TTA 3 Bar MAP sensor PowerLogger scan tool BstC electronic boost controller Caspers Electronics plug & play MAFT Pro Harness Innovate LC-1 wideband oxygen sensor w/custom installation box TRANSMISSION BOP Turbo Hydramatic 400 (3spd) 9.5" West Coast Racing torque converter 3500 stall Reverse manual valvebody Redneck Transbrake Alto Red clutches Kolene steel plates Alto direct Power Pak Alto Red oversized direct band Roller bearings throughout Hardened intermediate shaft HD intermediate direct drum HD 34 tooth sprag & race Boost valve kit Case saver kit HD centre support AISI 1045 steel forward clutch hub Hardened stator HD output shaft Rebuilt front pump w/ restrictor Teflon ring seal kit TCI Deep cast pan Trans speedomoter ratio adapter REAREND & DRIVELINE Custom 4130 seamless chromemoly 3" driveshaft HD Spicer 1350 yoke HD Spicer solid U-joints Custom driveshaft loop Factory 8.5" G80 (positraction) rearend w/welded axle tubes HD 3.08 ring & pinion set SUSPENSION & BRAKES Front Vacuum brake conversion w/B-body 1-1/8" bore master cylinder Robert Adams' 12" 1LE brake system w/Hawk HP+ pads Tubular UCAs Boxed LCAs w/ Global West Del-A-Lim bushings & Moog HD lower ball joints Moog Z28 spec springs (5664) 800lb/in Bilstein shocks 1LE 36mm hollow swaybar w/ Moog G2 bushings & endlinks Rear 2002 LS1 disc brake conversion Brake pressure booster solenoid UMI LCAs Bennets' single adjustable UCAs KYB Gas-A-Just shocks Hellwig Pro-touring swaybar Moog HD springs (5659) 200lb/in WHEELS & TIRES Black Plastidipped Simmons FR17 Front: 17x9.5s w/275/40R17 Falken 452s Rear: 17x11s w/315/35R17 Nitto NT05R Drag Radials BODY & CHASSIS Fiberglass front bumper Aluminum front bumper shocks Custom 6-pt chromemoly roll bar INTERIOR G-Force 6-pt racing harness Kenne Bell "ash tray" switch plate Custom reverse pattern console shift indicator plate Custom two tone interior using factory colours Late-model GM "map lite" rearview mirror ELECTRICAL Custom fuel pump hotwire kit Custom Chassis/engine ground upgrade COOLING Modine aluminum radiator (951) Modified 160* Mr. Gasket SBC thermostat Derale transmission oil cooler w/ fan & relay
