Author Topic: SES Lite On-Engine Cutting Out-No MAL Code  (Read 3317 times)
« on: September 27 2015, 11:16:29 AM »
Had a gentleman contact me. It's an 87 TR...stock. Engine dies out for a couple of seconds...SES lite comes on solid...engine comes to life again...SES lite goes out. No MAL code on the SM. This is intermittent. Any ideas?
Re: SES Lite On-Engine Cutting Out-No MAL Code
« Reply #1 on: September 27 2015, 11:48:59 AM »
try cleaning the chip and socket contacts and replug it?
Sounds like it is losing electrical power momentarily... might check the positive cable to the starter to make sure it is tight and not shorting against the downpipe or header before it gets to the starter.  Also make sure the orange wire is not frayed or somehow not making a good connection to the battery
« Reply #2 on: September 27 2015, 01:55:06 PM »
Steve, he lives 90 minutes away. I relayed the info to him. He's one of these guys that actually listens. :) I had him install a new fuel pump...hotwire kit...chip and injectors from Eric...AFPR... wires...plugs. ..boost gauge...FP gauge...recore d rad...water pump...and SM. Only thing I couldn't talk him out of was a 3" DP. He did take my advice and get an RJC tho. :) I'll keep you posted...and thanks.
I'm doing the valve springs on it next month.
« Reply #3 on: September 28 2015, 09:17:22 PM »
Whats the frequency of the failure? ECM getting hot?
« Reply #4 on: September 29 2015, 04:13:19 PM »
Dave..it's intermittent. I never asked him about the ECM getting hot. Waiting to hear back from the things Steve asked to check. The car is in Kingston...90 minutes away.
Offline bescurred
« Reply #5 on: October 10 2015, 08:45:59 PM »
Not sure if you got this figured out...
I had that happen once and my positive cable was arching on the driver side manifold....HT :powersix:
