Author Topic: Not again.  (Read 13550 times)
Re: Not again.
« Reply #30 on: November 08 2015, 06:13:40 PM »
Ok Steve, your theory is more than likely correct. Lol. I've replaced the battery in the car because the old one was done anyway. Had been in the car for 9 years. Lol. But, the fuse is still blowing. And, it's NOT during cranking, its just turning the key to on. This makes more sense than the scenario I provided the first time. I'll start back over from the beginning so I can find the culprit. I unplugged the ECM, and the fuse still blew. I'll keep you guys posted.
Re: Not again.
« Reply #31 on: November 08 2015, 08:05:35 PM »
Mine had a problem where the injector harness was shorting near the egr valve. Im not sure yours is similar but you could look on the manifold there and see if the harness is on the egr valve.
Re: Not again.
« Reply #32 on: November 08 2015, 10:09:05 PM »
Thanks Rich, I'll check that out as well!
Re: Not again.
« Reply #33 on: November 09 2015, 10:39:57 AM »
delete
« Last Edit: November 09 2015, 11:16:22 AM by Steve Wood »
Re: Not again.
« Reply #34 on: November 09 2015, 11:12:02 AM »
delete
ignore the diagram...wron g fuse
« Last Edit: November 09 2015, 11:19:27 AM by Steve Wood »
Re: Not again.
« Reply #35 on: November 09 2015, 12:07:27 PM »
so the diagram showing now I should ignore?
Re: Not again.
« Reply #36 on: November 09 2015, 02:04:22 PM »
yep, I thought I looked back and you said the ecm-sol fuse was popping...but I looked again, and it still says ecm-ign which is what I gave you the info on before
Re: Not again.
« Reply #37 on: November 09 2015, 02:08:14 PM »
here is the correct diagram....see if it pops when the module is disconnected as well
Re: Not again.
« Reply #38 on: November 09 2015, 03:36:13 PM »
Awesome diagram. Pretty basic! Thanks. I'll check it out
Re: Not again.
« Reply #39 on: November 16 2015, 11:15:06 AM »
ok ok, so apparently my knock gauge was the problem. The signal wire from the knock gauge I was running into the purple and black wire. The connection was fine, but a bit of the wire was exposed. Idk if the signal wire from the knock gauge was pinched or what, but after eliminating the splice between the signal wire from knock gauge to the ignition wire, all was well.  :cheers:
« Last Edit: November 16 2015, 11:29:04 AM by phil_long »
Re: Not again.
« Reply #40 on: November 17 2015, 09:01:53 PM »
Dunno how easy we are going to let you off, guy_who_makes_ harness_for_a_ living
Re: Not again.
« Reply #41 on: November 18 2015, 08:47:34 AM »
LMAO!!!!!!!!!!!! I dont make harnesses for a living. Lol. There is no excuse for it though.  :(
